Newbie Problems!
Old 03-15-2008, 12:16 PM
djrazr's Avatar
Unhappy Newbie Problems!
I wonder if this other problem i just found it my 95 4Runner 4X4 V6 has, is related to this https://www.yotatech.com/forums/f116...roblem-140093/
From the earlier post, i rigged it and drove her around town.
Today
I heard this tapping noise coming from here. Normal or DIY fix?
She ran fine. When i got to a stoplight, i started smelling a slight odor coming through the vents. I got home and popped the hood and seen mist of smoke coming from this location here
I looked under her, and seen nothing leaking. Went inside for a few minutes and seen some drops of oil?on the ground here
I got under the truck and seen this. something is leaking
I then checked oil dip stick which is full. I checked the radiator reserve. Im so use to seeing green
Any Help would be greatly appreciated. I know some about cars, but not a whole lot so please be detailed step for step. I just want to get her running. She is not over heating
Thanks
Old 03-15-2008, 02:27 PM
Snotrocket's Avatar
Looks like you have an oil leak somewhere. It's hard to tell where it's coming from in the pics.
Take it to a local shop and they should tell you whats wrong with it.
Old 03-15-2008, 02:52 PM
07sbock's Avatar
It is the valve cover gaskets most likely. Or the rear main seal. Thoes two go bad on the 3.0 4runners.
Old 03-15-2008, 03:54 PM
djrazr's Avatar
Are they easy to replace? I will do a search and see if there is a way to do it. Hopefully it's not that hard. I dont have a service manual but i did download it off this site
The thing is she doesnt leak if she sits in the garage overnight. She leaks after she's warmed up. Once she cools down, she stops
Old 03-15-2008, 04:24 PM
HelliphinoN8's Avatar
3.0's suck. Should've got a 4cyl. They're just as quik. LOL!
Old 06-13-2008, 08:56 PM
Sponsor
Tofer's Avatar
my god your a toolshed..... thank you for this very useful information to helping this guys problem..... :bigclap:
Old 06-13-2008, 09:28 PM
CyMoN's Avatar
lol nice bring back of a 3month old thread and FYI to the toolshed the 4 bangers are not as fast as the 3.0
I miss using my 3.0 for pulling my trailer.
my 4banger can pull it but not as fast.
when changing the valve cover seals make sure to get a new intake gasket at the same time.
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
RaginAsian91
All Other Toyota Swaps
08-23-2015 10:27 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
garagespace
07-09-2015 08:37 AM
Quick Reply: Newbie Problems!
