Newbie looking for input on first build, fuel milage, and 5.29's with 31's
Old 12-07-2007, 11:54 AM
  #41
liferunner2's Avatar
So, if this is the case, then how do I fix this, and does the torque convertor just use the trans fluid? All my cars to this point have been manual, which I have successfully relaced, but I have never worked on an auto. Thanks.
Chris
Old 12-07-2007, 05:31 PM
  #42
tc
tc's Avatar
You fix it by gearing properly for your tire size - that has been my point all along.
Yes, the fluid in the torque converter is the tranny fluid. (the torque converter is actually the pump that pressurizes and circulates the fluid)
Old 12-07-2007, 07:39 PM
  #43
davenjai's Avatar
Originally Posted by tc
If you let off the gas a little, you will see it shift like a 1/2 gear - that's the torque converter locking up. When the torque converter is not locked, you are generating A LOT of heat in the tranny - not good.
http://auto.howstuffworks.com/torque-converter.htm
http://auto.howstuffworks.com/automa...ansmission.htm
Why would a 4:88 with 31's not be locked up at 70?
Old 12-08-2007, 08:42 AM
  #44
It's the stock set-up from the factory. Would they really have provided an option that would not allow for TC lock-up?
Anyways, I can't regear my diff., so I would have to buy a whole new third and I don't have the cash for that right now.
Chris
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
RaginAsian91
All Other Toyota Swaps
08-23-2015 10:27 AM
coffey50
07-28-2015 10:55 AM
dinks07
07-15-2015 05:34 PM
garagespace
07-09-2015 08:37 AM
Quick Reply: Newbie looking for input on first build, fuel milage, and 5.29's with 31's
