New Timing Chain install problem help please!
Old 01-03-2011, 07:00 PM
Toyotadragger1's Avatar
Hello New to the forum,
I have a 92 toyota 22re 4x4 Truck had alot of problems when i bought it I straightened them out and then heard the sound of the timing chain, so I tore the truck down and replaced the chain,gears,tensioner etc.. put it back together and installed the distributor, problem being when I set the timing to 5degrees it has no power, it idles fine but you put it in drive and go to take off it has nothing you hold it to the floor and your barely moving, anybody has this type of problem or know a solution maybe? I pulled the valve cover back off to check that at 0 the cam marks on the gear are at about 11 and they are. so at this point im lost any help?
Thanks
Old 01-03-2011, 07:30 PM
mightymouse's Avatar
so advance the timing a little and see what it'll do. Are you sure you timed it proper? Are you sure you stabbed the distributor right? With my old 22re and all the mods done to it i advanced the timing quite a bit.
Old 01-03-2011, 08:38 PM
874runnersr5's Avatar
id double check to make sure your not out a tooth on your dist.
Old 01-04-2011, 06:49 AM
xxxtreme22r's Avatar
are you setting timing 5 BTDC with the jumper installed? You sure the jumper is connected properly? Ie the idle drops when connected. Also as stated above, make sure the distributor is not a tooth off as well.
Old 01-04-2011, 06:58 AM
fierohink's Avatar
+1 on xxx
If you set the timing without bypassing the computer, as soon as you start the truck it will try to advance/retard timing to correct on it's own. But there isn't enough room for correction in the magnetic advance to run right.
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
hexrain
06-27-2015 06:17 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: New Timing Chain install problem help please!
