new and ride a 88 pickup
im new to this forums. i own a 1988 yota pickup and a ford zx2 pos. well i got my yota for 500$ lol and im very curious on my limits with the truck.
its a 4-speed. i wanted to know if theres anyways i can get a tranny to fit it to make it a 5-speed. then suspension wise i would like to lower it and engine wise. any cheap swaps? thnks guys hope we get along fine
if its a 4 speed, it must be an auto right? I believe 83 was the last yr they had 4 spd manuals.
Common engine swaps are the 3.4(can be supercharged), supra motors(7mgte ), chevy 4.3 v6, chevy 5.3 v8, ford 5.0 and tons of others, since your getting a new tranny, you can either get a yota 5spd, or the 5 spd from those certain engines as well, most have aftermarket support.
I am not sure if a 5 speed would bolt in, but I would assume that a w56 would bolt in place of a w46, but I do not know this for a fact. 4 speeds were put on 4x2s, even in later years. 4 speeds have a higher geared axle, so 4th is similar to 5th in a 4x4. You might want to keep that in mind if you swap to a 5 speed. 5th gear will be almost unusable with the 4 speed axle ratio unless you swap in an engine with lots of low end torque.
I found some information in my 1987 brochure. Here are the axle ratios that are listed:
4x4 5 speed manual: 4.100
4x4 4 speed auto: 4.300
4x2 5 speed manual turbo: 3.417
4x2 5 speed manual: 3.727
4x2 4 speed manual: 3.071
4x2 5 speed manual 1 ton: 3.900
4x2 4 speed auto 1 ton: 4.100
There is also a 3.583 listed that I am unclear on what it is for, but it appears to be for a SR5 Xtracab Sport.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
