New R&P as well as locker change
Old 02-11-2007, 08:06 PM
Lysmachia's Avatar
Question New R&P as well as locker change
Hey guys,
So Troy and I are starting our research on what to do about my front broken ring and pinion. Currently I have 5:71's in there. We really need to replace it with 5:71 since I can't afford to re-gear the rear and I need the low gearing since I have the 3-slow with an automatic on 35's. (So I can at least go 85mph on the highway on my way to Moab).
While I am in there, I might as well upgrade to a selectable locker since currently I have a Detroit Tru Track - and well with the way I wheel I get a front tire off the ground too much and lose the use of the locker unless I start playing with the break (and even then I only get 3/5ths resistance).
So what to do?
Buy R&P, and then a locker seperate, and hire it out to be installed. (Sorry I won't touch my gears!)
Buy a set up 3rd member?
Anyone got what I need?
Discuss amongst yerselves....
Old 02-11-2007, 08:12 PM
Lysmachia's Avatar
Ok so more info:
* If I do an air locker I'll need the compressor too since I have a rear E-locker.
* I've got a quote from Randy's Ring and Pinion: (www.ringpinion.com) Quote from Randy's ring and pinion - for assembled Toyota 8" thirdmember with 5.71's and an ARB locker ('85 front axle).
Cost: Complete 3rd member with a new drop out and no core charge is $1370.00
Originally Posted by AxleIke
Talk to Adrian before you do that...He got a fully set up diff from the west coast (i believe) and had it crap teeth on the 5.29's. Something to check into at least.
Thanks! -Molly
Old 02-12-2007, 07:31 AM
tc
tc's Avatar
True
:pat: No, you have a Detroit locker in the rear - it's always locked.
However, we COULD do an elocker in the front probably...
Old 02-12-2007, 09:53 AM
Albuquerque Jim's Avatar
I thought I saw a HP 8" E-locker FS on here not too long ago.
Edit: Here you go: https://www.yotatech.com/forums/show...inion+e-locker
Old 02-12-2007, 05:57 PM
Sonofmayhem's Avatar
I found some used 4.56s for my truck and bought them off of here and colorado4x4.org, then i just ordered an aussie... im gonna lock the front in the summer. if i were you id get a complete diff from them.
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
Daneums
07-28-2015 11:57 AM
coffey50
07-28-2015 10:55 AM
A2theK
07-12-2015 10:46 AM
Quick Reply: New R&P as well as locker change
