New Problem has shown its ugly face - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-27-2009, 11:18 AM   #26 (permalink)
camo31"10.50"'s Avatar
ya'll are slackin off again..dang guys..help me out..i need to have this bugger fixed by tomorrow..
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 10-27-2009, 06:03 PM   #27 (permalink)
__________________
Old 10-27-2009, 06:49 PM   #28 (permalink)
Try the junkyard anyways for the acc pump, you never know. I had the same problem, was going through fuel filters on a regular basis, then the fuel pump died, then my carburetor started running like crap, the culprit was a rusty gas tank. I say change the fuel filter, its quick, cheap, and easy anyways, and don't be afraid to go crazy with the carb cleaner either
__________________
1986 Pickup, 22RE, Regular Cab longbox, stock, but not for long
Quote:
Originally Posted by Skinsfan6 View Post
Or I could just mount those james bond rocket launchers I've always wanted under my bumper to "scare" the deer away.
Quote:
Originally Posted by Matt16 View Post
My truck catches fire when ever I turn a corner because I have a locker.
Yotapowa is offline
Old 10-27-2009, 07:14 PM   #29 (permalink)
i've been trying the junkyards..none have any acc. pumps for my truck..lol..they got em for older 1st gen 22r's..but they're vacuum operated..mines mechanical..lol
its not the pump..lol..although the tank is probably nasty..my 2 filters are new..and the problem persists..its the acc. pump..has to be..
at least it better be..LMAO
__________________
Old 10-27-2009, 07:22 PM   #30 (permalink)
Hmm. Hopefully you can find one. And if you were thinking of a carb rebuild, I'll warn you it can be pretty time consuming and complicated with all the linkage on the back lol, but well worth it, my truck ran amazingly after I did mine
__________________
Yotapowa is offline
Old 10-27-2009, 07:32 PM   #31 (permalink)
i believe that i could handle it..lol..if i have any problems then our mechanic can help me..he rebuilt the carb for my '80 and it came out great!..
all i gotta do is make sure i remember where everything goes..lmao..then put it all back together...but before that the carb body would get sent off to be cleaned..lol
__________________
Old 10-27-2009, 07:43 PM   #32 (permalink)
yota4runna's Avatar
How did you test your anti-diesel solenoid? If there's no voltage to that, or if it's defective, the truck won't idle. With the ignition switch "on" you should have 12V. at the solenoid. With the truck turned off, [so you can hear], put 12V. to the anti-diesel solenoid. It should click.
yota4runna is offline
Old 10-28-2009, 11:57 AM   #33 (permalink)
anti diesel solenoid.........what the F is that..lmao..
do you mean the Idle Cut Solenoid?..i was told to just unplug it and see if anything changes..nothing changed lol..if this is what you are talking about then i will test the voltage when i get home and listen for it to engage..
still need an acc. pump though....lol..still can't find one.....................
__________________
Old 10-28-2009, 04:23 PM   #34 (permalink)
come on dude..you can't post information then not check back with the thread..LOL
__________________
Old 10-28-2009, 06:59 PM   #35 (permalink)
yota4runna's Avatar
OK. I just looked at the Factory Service Manual, and Toyota calls it a "Fuel Cut Solenoid." It is designed to prevent the truck from "dieseling", also called "running on" after turning the ignition key to "off." Here's how it works: that solenoid has a spring-loaded plunger at the end that shuts off the fuel supply to the carburetor idle passage. When you turn the ignition key to "run," 12 V. is applied to that solenoid, and the plunger is retracted, allowing fuel to flow to the idle circuit. When you turn the key to "off," the spring pushes the plunger into the idle passage, cutting off the fuel supply to the idle circuit, and preventing the truck from dieseling.
If you don't have 12V present at the solenoid with the key "on," the spring on the plunger will keep the fuel shut off to the idle circuit, and the truck won't idle.
If you have 12V present at the solenoid with the key "on," but the solenoid is defective, then the plunger will stay "in" and keep fuel from getting to the idle circuit, and the truck won't idle. You test this by listening for the solenoid to "click" when you apply 12V to it.
In this picture of a 1989 Toyota 22R carburetor. the Fuel Cut Solenoid is the cylinder with the black and white wires coming out of it. Some earlier models may have only one wire coming out of it.
Old 10-28-2009, 07:22 PM   #36 (permalink)
heyy...that helps ALOT (with the pic and explanation..lol) i did unplug it..to see what would happen..but i didnt test it..and i didnt get around to testing it today..lol
i will test that in the morning and report back..in the meantime
if i spray carb cleaner (while the motor is running) around the back of the carb..it idles quite a bit smoother..but wont stay idling..it just seems kinda weird that CARB CLEANER would make the truck idle better???
specifically if i spray around the back of this little bugger..that i THINK is the Idle Up Diaphragm..
the little brass lookin thing with the vacuum line goin to it
and that's where it is located..(center of pic...again..the little brass thingy..lmao)
still can't find an accelerator pump...im gonna try the Carb rebuilder places..see if they can get me one..
__________________
Old 10-28-2009, 09:44 PM   #37 (permalink)
stock87's Avatar
Send a message via ICQ to stock87 Send a message via AIM to stock87
Alright, you're kind of on the right track, but you're looking at the wrong items.
The carb cleaner will make it run better because it's taking the place of the air getting sucked in the vacuum leak.
Check this page out, it will answer all your questions:
http://www.bluebassdesign.com/boonin/carb_faq/
The better NAPA rebuild kits that take the carb tag # into account should come with a new AP, but I doubt that's really your problem. The boot is just a dust boot, and doesn't affect air or fuel.
I could tear one of these carbs down in my sleep, so post back with any further questions you have.
__________________
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
stock87 is offline
Old 10-28-2009, 10:13 PM   #38 (permalink)
i think..by the time im done..the carb is gettin rebuilt..
not only do i have this problem..but if i FLOOR it..(like...suddenly from idle just FLOOR it...not gradually but IMMEDIATE) then the truck stumbles and will act funny..i cant really explain it..the DS choke will flutter back and forth..and the truck almost dies...i think it's flooding it...as in when i floor it then the truck is getting too much fuel...and my mechanic thinks that it's not getting enough fuel..LOL..
im going to mess with the mixture screw a little tomorrow too...as the cap thats supposed to be over it......isn't there anymore..so it's likely backed out a little bit and is causing the truck to run way rich...
one way i know it's runnin rich..is if i floor it..and it starts to bog down..i can let off and kinda 'pump' the pedal once and a little black smoke will come out of the exhaust..which is unburnt fuel..
so things to do tomorrow...check the fuel cut solenoid, and check the mixture..lol
__________________
Old 10-29-2009, 03:50 PM   #39 (permalink)
ok..so i checked my mixture..and the screw was 8 full turns out...........
so i screwed it all the way in..brought it out 4 turns (factory spec..about) a she still wont idle..lol..
im gonna check the idle cut solenoid in a few mins whenever the rain lets up..lol
keep the ides comin guys!
__________________
Old 10-29-2009, 04:15 PM   #40 (permalink)
ok guys...pulled the idle cut solenoid because i was getting power to it..but didnt know if it was working..so i took it out and to visually see if its working..and its not moving???
this is it..and BTW this is with the key on and and the solenoid plugged up..
__________________
Old 10-29-2009, 05:38 PM   #41 (permalink)
anybody?? got any ideas??
__________________
Old 10-29-2009, 06:46 PM   #42 (permalink)
__________________
Old 10-29-2009, 08:53 PM   #43 (permalink)
come on guys...you just keep disappearing on me...lol
__________________
Old 10-30-2009, 06:24 AM   #44 (permalink)
Is it a two or a one wire setup to the solenoid? if it's a one wire, it will need to be grounded to work.
just take a couple of jumpers right off the bat and touch them to the right connectors on the solenoid, It should pull back when you hit it with the power. You did say you have power at the wires right??
broncbob is offline
Old 10-30-2009, 02:20 PM   #45 (permalink)
well now...i went searchin around under the hood..and i dont have power at the big green plug for the solenoid....i didnt bother to check the other wires coming out of the plug to see if they get power..LOL..guess i need to do a little more testing..
the solenoid is a 2 wire set up..and idk how to get to the connectors on the solenoid itself..the wires go into some kind of rubber piece on the solenoid lol..more investigating needs to be done i know..and im goin to check on everything right now
__________________
Old 10-30-2009, 03:36 PM   #46 (permalink)
have you had the carb apart to check for build up?
cooperk85 is offline
Old 10-30-2009, 08:56 PM   #47 (permalink)
stock87's Avatar
Honestly, at this point I'd start checking fuses. You probably popped the power to the carb 'computer' when you were messing with the stereo.
__________________
stock87 is offline
Old 10-30-2009, 09:04 PM   #48 (permalink)
now i've looked over alllll of the fuses in the whole truck..none are blowed?..i checked the ones under the hood by the battery..checked the ones behind the DS kick panel..and checked the 2 behind the glovebox..to my knowledge that's all the fuses...however i haven't check any of the relay's???..
__________________
Old 10-30-2009, 09:06 PM   #49 (permalink)
and no i haven't had the carb apart yet...but if none of these easier things work out....then i will sure as hell rip it apart send it off to be cleaned..then put er back together..im about 90% sure it needs to be rebuilt anyway..lol
__________________
Old 10-31-2009, 04:12 AM   #50 (permalink)
haha, idk if this would help any but how did you wire up your radio? idk if this is the right way but my friends when the put in systems usually wire theirs to their ignition then to their battery. Also when you wired up the radio you possibly could have created a short. try to take the stereo out. stupid idea but everything is worth a try right?
Tags
1986, 22r, accelerator, aux, carb, choke, diaphragm, english, fast, idle, opener, pump, read, soldier, teacher, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
