new guy, new problem
Old Jan 28, 2007 | 01:27 PM
truckless's Avatar
hi I am new to the forums. My wife and I just got a 1998 2.7, 4 cyl. so far we replaced the radiator and thermostat. well monday she called and told me that the truck wont start. just yesterday we replaced the pump and filter and checked the relay and fuses(sp). it cranks over and wants to start but won't. I would be thankfull for any ideas. thanks
Old Jan 28, 2007 | 01:43 PM
Lifelongtoy's Avatar
Listen for the fuel pump to make a noise when turning the key to ON position. No sound means no fuel. Make sure relays have a good connection. Check cylider compression also. Other that that I think we need more info.
Old Jan 28, 2007 | 01:49 PM
mt_goat's Avatar
Welcome to Yotatech.
Your thread will get more of help next time if you put your subject in the title and if you post in the correct forum. This is the forum for 86-95 trucks
One tip on searching; use the "advanced search" and search for your key words in the "Search Titles Only" option.
Don't be too shocked if the mods delete this thread Read this: https://www.yotatech.com/forums/showthread.php?t=74566
Old Jan 28, 2007 | 01:55 PM
MMA_Alex's Avatar
just a heads up this is the 86-95 forum. there is a forum that covers 98's, and you'll probably have more luck there.
if it wont start and cranks over you're going want to check for spark, fuel, and compression. If it ran recently, and had problems after doing work on the fuel system i'd recheck the work you did first.
Old Jan 28, 2007 | 02:05 PM
truckless's Avatar
I wont. bet probaly happens quite a bit. when we hooked everything back up you could hear the pump kick on. I tried to start a few times so it would suck up fuel, nothing.
Old Jan 28, 2007 | 02:34 PM
Godzilla's Avatar
does it start at all or start and quickly die? check any vacumn hoses and all your intake, maybe even try cleaning the maf since the fuel and starting problems dont appear to be the issue
Old Jan 28, 2007 | 04:21 PM
truckless's Avatar
ok I was mistaken about the pump when we turn the truck on the pump doesnt go on but when you turn the key off it turns on. I was just to busy yelling and screaming at to really pay attion. also is there a relay in the dash.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Jul 23, 2015 08:08 PM
timmJ
Jul 7, 2015 02:01 PM
karbin
Jul 5, 2015 11:37 PM
