New 95 HELP!!*
Old 09-25-2014, 10:44 PM
oreopenguin536's Avatar
Ya I think I got a main part of it...it just acted up on the way home though, going up hill so maybe I didn't. .. however the ticking is still there
Old 09-26-2014, 11:03 AM
nortonian's Avatar
The clicking that starts after it warms up could be an exhaust manifold leak.
Old 09-26-2014, 01:16 PM
That would explain alot
But why only when it's warm?
Old 09-26-2014, 06:37 PM
thefishguy77's Avatar
It could be when it's cold materials contract making the crack/leak very small.but when it warms I'm the crack could expand and get worse. Just a thought.
Old 09-26-2014, 10:12 PM
  #25
That would make a ton of sense
And would the white smoke be part of that?
Old 09-27-2014, 06:42 AM
  #26
I didn't see any mention of white smoke in previous posts. Is it out the exhaust? Then it would be antifreeze. Check your oil (change it) and look for water in it. Also look at the oil fill cap see if there is water vapor (white residue) on the underside of it. White smoke is one of the indicators of a blowen head gasket. If you have or can rent/borrow a compression tester that would tell you and us a lot. Most parts stores rent them fairly cheap. You could probably buy one for $20 or so from harbor freight. If its a head gasket you probably got a lemon and should see if you planned future engine swap is doable now. Good luck keep us posted.
Old 09-27-2014, 10:42 AM
  #27
I actually just noticed the smoke recently when I was already looking at the back of the car and saw it shoot out....no white residue though
Old 09-27-2014, 06:40 PM
  #28
Do a compression check. I only know the 22re motor. The 3.0 might have different problems. But still do a compression check.
Old 09-27-2014, 09:31 PM
  #29
I'll get one tomorrow and let you guys know
Old 09-28-2014, 05:41 AM
  #30
nortonian's Avatar
Smile
Don't know why, but mine did that when I first got it and the mechanic said it was a manifold leak. It wet away when I put in the headers.
Or maybe it was just covered up.
Old 09-28-2014, 02:41 PM
  #31
Haha outta sight outta mind right?
I would get headers but if I do a engine swap why put money in it? And I need suspension lol
Idk, are their mods that are made for the 3.0s to give it some more kick than stock? Cam? Can they handle boost decently? If they can then why not twin turbo it?
Old 09-28-2014, 11:03 PM
  #32
pewdiepie's Avatar
why does my post's keep ending up in the wrong thread?
Old 09-28-2014, 11:20 PM
  #33
No idea lol
