Needed: Vac Diagram for '90 22RE (Cali) AT, AC
Can't find it. Sticker under the hood is way faded. Any help would be appreciated. Under hood shots of said vehicle would be optimal. Much thanks!!
Ok, here's some pics I got this morning.
Note: I unplugged the lines that went from my power steering idle up connection, 'cause it didn't do anything but drop my rpms a bit. I realize the line I routed back from the intake to the idle up valve is wrong, but I didn't have a cap on me at the time. Also, everything else is as I received the vehicle, no changes. One thing I do note is that my AC idle up valve does NOTHING. I've replaced both the valve and the actuator, and verified that the actuator fires. Nothing. Screwing in the plastic adjuster does nothing, but if you pull it out completely it causes the major vac leak and kills the motor. This I do not understand...
montanatruck
02-26-2017 07:07 AM
