Need pic of rear window assembly
Old 04-20-2007, 05:28 AM
WFO
WFO's Avatar
I recently bought a '91 4Runner with a blown head gasket. The guy had already started taking the motor apart so I coulndt really check to make sure everything worked. Anyway I asked the guy if the rear window worked. He said yes it works.
Well I get the truck running and find out the rear window does not work. So I take the cover off the tailgate last night to see whats wrong and theres 2 switches/relays (not sure) just hanging there and theres a little blue connector going nowhere. Im thinking that goes to the motor??
I think I can figure out where the 2 switches, or whatever they are, go but I have no idea where the motor goes. Does anyone have a picture of how the motor is mounted?
Thanks in advance
Old 04-20-2007, 09:47 AM
WFO
WFO's Avatar
Could anyone exlain where it goes? What side, top, bottom? Ive never seen one before so its kinda hard to pictuure where its supposed to go.
Old 04-20-2007, 10:04 AM
bktaco's Avatar
the connector should have a mate - find and plug! zip tie it too, it will fall apart again at some point.
Old 04-20-2007, 10:28 AM
WFO
WFO's Avatar
the blue connector is right in the middle near the bottom. I looked and looked but theres nothing else it could connect to. Also I couldnt find the motor so im thinking its missing, but im really not sure.
Oh and he also ran a bolt through one of the gears to keep the window up.
Old 04-20-2007, 11:45 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Gosh, the motor is real obvious. It's black and cylindrical mounted right on the regulator. So, if you don't see one it may be missing.
I do not recall how these things are laid out, but I do remember someone having posted some pics of the assembly a litte while back. Maybe a couple months or more.
Old 04-20-2007, 12:28 PM
Neaners's Avatar
Not sure if this will help, but here is the link to my 95 FSM - http://the-roo.com/4runner/
Old 04-20-2007, 03:14 PM
Neaners's Avatar
better yet, I just happen to have my panel off of my truck so I took some pics for you.
Old 04-23-2007, 04:21 AM
WFO
WFO's Avatar
Sweet!
Now I can see where its supposed to go.
Thanks a lot!
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
crashburnoveride
07-10-2015 06:39 AM
coryc85
07-06-2015 04:07 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Need pic of rear window assembly
