Need help w/ Aisin Hubs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-18-2009, 02:46 PM   #1 (permalink)
Gator's Avatar
I just got through putting a new cv axle on my truck and have a question about the hubs. I have Aisen hubs and was wondering if it is possible to put to much grease in there when reassembling everything. Once I got it all put back together, I locked in the hub and spun the rotor to check everything out and it locked in like it was supposed to, but it doesn't seem to be unlocking when Iturn it back to "free".
Please help.....
__________________
Current Setup: 94 X-Cab 4x4 w/ 3.0, Auto, 1.5" BJS & Shackles, 33x12.5-15 BFG MT's, Detroit locker w/ 4.88 gears, ISR and Air Box mods, All-Pro winch bumper, Trail Gear Rear bumper, Warn XD9000i, custom body work by trees and rocks.
Future Mods: 1UZFE Conversion, A340H to R150F conversion, SAS, dual cases, 12v Air Compressor & tank.
Last edited by waskillywabbit; 04-18-2009 at 03:46 PM. Reason: Title clarity per posted sticky
Gator is offline
Old 04-18-2009, 03:01 PM   #2 (permalink)
mattaway's Avatar
the guy that taught me said too much grease is just as bad as not enough grease.
too much grease traps in heat. not enough grease creates too much heat
__________________
'92 Pickup Ext. Cab 22re 5spd 4x4
31/9.5 TSL Radials
Rattlecan'd Olive Drab
DD/WW!
mattaway is offline
Old 04-18-2009, 03:07 PM   #3 (permalink)
Gator's Avatar
how much should be used then? I literally packed it till it was full thinking it would spread through along the shaft of the cv axle and cover everything.
I am fixing to go back out there and clean some of it out, but need to know how much is good.
Thanks in advance
__________________
Gator is offline
Old 04-18-2009, 03:14 PM   #4 (permalink)
mattaway's Avatar
i'd say pack the bearings good, and put a glob that takes up about half the hub.
__________________
31/9.5 TSL Radials
DD/WW!
mattaway is offline
Old 04-18-2009, 03:29 PM   #5 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
yeah, too much in the body of the hub will create a suction effect and keep the insides from releasing
when I did mine, I just packed the bearins, bolted all that in, then smeared a little on 2 or 3 fingers and just ran over the inner walls of the hub, and on the outside of the locking spline (for lack of the technical term ), and everything's been working well
iamsuperbleeder is online now
Old 04-18-2009, 03:46 PM   #6 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Pack the bearings with grease.
Lightly coat the internals of the manual hubs.
And they are "AISIN"
waskillywabbit is offline
Old 04-18-2009, 03:49 PM   #7 (permalink)
bigt's Avatar
yeah just finger grease the spring and dial and everything dont need much!!!
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 04-18-2009, 03:50 PM   #8 (permalink)
mt_goat's Avatar
Here's a good write-up on the Aisin hubs:
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 04-18-2009, 04:22 PM   #9 (permalink)
that's the walk-through I followed the first time I did mine it's a good one
but now I would do them blindfolded, lol
Old 04-18-2009, 04:51 PM   #10 (permalink)
I will pack the bearing with normal bearing grease, but in the hubs, I will use the figure method with white lithium grease. Hasn't failed me yet.
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it
RaginYota is offline
Old 04-18-2009, 04:52 PM   #11 (permalink)
Staff
Quote:
Which "figure" method would that be?
Figure four hub lock?
Old 04-18-2009, 07:32 PM   #12 (permalink)
a4runnerfreak's Avatar
Location: Grew up in S.C.V, SoCal.....now here in Cougar, Washington
Send a message via Yahoo to a4runnerfreak
I've heard that, like falling in love, the figure 4 hub lock is hard on the knees.....lol
__________________
Quote:
Originally Posted by waskillywabbit
Wheel IFS. Wheel SAS. Wheel your big wheel. Just wheel.
Quote:
Originally Posted by fustercluck View Post
Now if he has broken the law, then he should spanked on his flabby pink bottom in public by oompa loompas.
Quote:
Originally Posted by girl_face View Post
tony! where have you been all my life?
1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's
a4runnerfreak is offline
Old 04-18-2009, 09:03 PM   #13 (permalink)
Quote:
LMAO... that is what I get for not proof reading my post!! Just to clear it up FINGER... not FIGURE...
Thanks for pointing that out!
__________________
Old 04-18-2009, 09:43 PM   #14 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
so... this would be the trademarked "RaginYota finger 4 hub lock"?
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 04-18-2009, 10:04 PM   #15 (permalink)
Gator's Avatar
Thanks to all. I got it figured out. I had not ever done a 4x4 service before and had a CV axle that was about to go. I went ahead and did the same as what all of you advised and it worked beautifully. One needed a little TLC, but it works better than ever now.
Richard
__________________
Gator is offline
Tags
1987, 22re, aisin, auto, back, hilux, hub, hubs, ifs, kits, manual, putting, rebuild, samurai, suzuki, view, walkthrough, warn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Removing/Installing Automatic Hubs - Auto Hubs yota4runna 86-95 Trucks & 4Runners 0 01-13-2009 02:32 PM
WabFab Off-Road Auto Hubs to Manual Hubs Conversion Kits waskillywabbit Vendor Advertising 0 03-16-2007 06:58 PM
I have a pair of IFS locking hubs - trade for/WTB SFA Hubs MtnToys The Classifieds GraveYard 8 09-19-2006 09:57 AM
Are ADD hubs pretty much just manual hubs that are always locked? GradSR5 95.5-2004 Tacomas & 96-2002 4Runners 29 11-14-2005 12:02 PM
Aisen Hub Bolts Krash Maintenance & Repair Archives 4 09-02-2002 09:11 AM
2009 InternetBrands, Inc.
