Need Help about my 4runner 1988. Plz
Old Sep 2, 2008 | 07:01 PM
Myers504's Avatar
My 4runner is a 88 new motor and trany.
but when I turn the truck over to start it starts and i can drive up to 10 miles than it will shut off and not crank back up. idk whats wrong last month i replace, starter ,alternator, battery, and battery cables.
any advice or help will be appreciated.
Old Sep 2, 2008 | 07:04 PM
tc's Avatar
tc
Motor, tranny, mods?
Old Sep 2, 2008 | 07:07 PM
Myers504's Avatar
lnot really just a half a block. and proformace headers.
but i dont think that would stop my truck at 10 miles.
but i have felt my starter and its brand new just put it in myself. its running real hot, so i change my cables. because the battery cables were very hot and now that ive changed them they are not hot so idk.
Old Sep 2, 2008 | 07:08 PM
lftd_86_yota's Avatar
I'll throw this one out there... afm?
Old Sep 2, 2008 | 07:10 PM
Myers504's Avatar
afm? what is that
Old Sep 2, 2008 | 07:12 PM
abecedarian's Avatar
so after about ten miles of driving, the engine just stops running and you can't get it started?
will the engine crank over like it's trying to start but just doesn't start running or is it when you turn the key nothing happens?
Old Sep 2, 2008 | 07:13 PM
air flow meter... could be a number of things, but my 89 (22re) did the same thing to me when my cold air intake bracket snapped and the intake pipe was seperated from the afm. It was just the first thing that came to mind. good luck
Old Sep 2, 2008 | 07:15 PM
Myers504's Avatar
its trying to crank over but it doesnt you no
Old Sep 2, 2008 | 07:37 PM
considering it happens when the engine has warmed up, and seems to go away after it cools down couple of things then-
coolant temp sensor for the ECU may be sending bad signals and causing the fuel mixture to be too out of whack for the engine operate properly.
thermostat or other cooling issue causing the coolant temp sensor mentioned above to send improper signals to the ECU
fuel pressure regulator not holding enough pressure and allowing the fuel in the fuel line (from being so close to the engine) to get too hot and vapor lock
Do you know how to check the truck for any computer trouble codes?
Old Sep 2, 2008 | 08:40 PM
tc's Avatar
tc
Kinda hard to diagnose anything until we know which freakin engine it is ...
Old Sep 2, 2008 | 08:49 PM
874runnersr5's Avatar
yeah, try to pull the engine codes.
Old Sep 2, 2008 | 09:39 PM
thook's Avatar
"headers"....as in plural
I'm guessing 3.0?
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
