Need Help!!!!!
Bad fuel injector or as was my case on my 87, corroded and broken wires going to the fuel injector on that cylinder. Try switching the fuel injectors from cylindes 2 and 3. If 2 still won't fire its probably the wiring. If 3 won't fire its the injector itself. There is a sharp bend in the fuel injector wiring close to the injector plug that can cause the wires to get brittle and break.
