need an engine wiring harness
I was doing a motor swap on two 4runners and the wiring harness was cut all to pieces on the new one. I was going to use the wiring harness off my old one but its a manual. The 4runner i am switching to is automatic so I need an automatic engine wiring harness for a 1987 toyota 4runner with a 22re fuel injected motor, does anybody have one lying around? I couldnt find one on ebay and none of the junk yards around me has one. any help would be appreciated/
You will need the ECU, as well. Most of the harness is identical. I would take the one good harness, for the manual, and add the connectors for the auto. Should just be the large white plug below the intake, and the portion for the auto itself. Option B, is to get the manual shift conversion unit. Use the manual harness and ECU, and control the auto manually.
steve miller
10-10-2015 01:40 AM
