Is it my head gasket
Old 01-19-2009, 01:20 AM
Marty78's Avatar
How can i tell if my head gasket is on its way out. the reason i ask is cus my engine wont burp. when it overheats i can hear a gurgling from under the hood. ive tryed everything to get vapour out. i constantly hear gurgling from the heater core as well.
Old 01-19-2009, 02:42 AM
rdlsz24's Avatar
Do you have mixing of oil and coolant? Or are you having to consistently add coolant? Another sign would be white smoke out your tailpipe.
Rob
Old 01-19-2009, 04:27 AM
baseballchamp157's Avatar
that gurgling is it when you over heat? because if so thats probably your radiator. yea but moking out your tailpipe would be a good way to check. ummm then you might try a compression test...im not sure about that one so anyone else
Old 01-19-2009, 02:15 PM
merace19's Avatar
Rob
X2
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
themightykhoner
08-11-2015 07:37 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Is it my head gasket
