My first time replacing injectors 88 4runner
Old 05-02-2009, 09:02 PM
MILLER 88DLX's Avatar
So this week I removed my fuel injectors. I have had a strong order of gas and a lost of power as well, not that I had much power before. I already change out the vapor canister and that did not help at all. I can say this, the injectors are more than likely originale! Not bad for 328,000 miles!!!!
I went to work pulling everything apart and sent my injectors off to Witchhunter to be rebuilt. The last few days I took the time to clean the Throttle body and the Upper intake. After 21 years WOW now thats alot of carbon!! I used mineral spirts, oven cleaner and host of other things to clean everything. Two days of soaking and three trips to the carwash and they are clean Next I took the time to add some paint and I'm pretty happy with the final outcome
I'm sorry I have no pictures of what the stuff look like before I clean it all up! ALL and all for my first time doing this I'm pretty happy with myself and will be happier when its put back together, turn the key and the Runner runs again!!
Here are some pics of my work.
http://s601.photobucket.com/albums/tt96/MILLER88DLX/
Old 05-02-2009, 09:08 PM
RMA
RMA's Avatar
That looks really clean, I think I have to get my injectors cleaned also.
I Have seen some other members paint their intake then they sand the top of the letters EFI and the square surrounding the letters , looks better. Break thinks up a bit.
Good Job !!!
Old 05-02-2009, 09:21 PM
I considered it but I wanted to do something different. Also I went with blue because alot of people use RED. Can not wait to see it installed!!!!
Old 05-02-2009, 10:16 PM
RMA
RMA's Avatar
Yea , I think it was a red one I saw.
Old 05-03-2009, 10:08 AM
space-junk's Avatar
the question is, does it run better? or was it all a waste of time?
Old 05-03-2009, 03:55 PM
Well I have not got the injectors back yet, so I dont know if it runs better or the same? I did not choose this I really had no choice the injectors were not spraying rite and leaking gas and the truck was not running well at all! The injectors had never been changed or cleaned and were in short shot and since I had everything off I figured I would clean 21 years of build up off the the intake and throttle body. Trust me I want to know and I'm looking forward to seeing if the trucks runs better, my guess is that it will. As for the paint I had it sitting around and figured what the hell. I also found that I was leakeing coolant from the thermostat housing and had some hoses that were crack so that got fix as well.
When I have it put back together I will make sure to let you all no the results!
Old 05-05-2009, 06:39 AM
sdstud212001's Avatar
So I was just wondering how much does it cost to get your injectors cleaned? I am getting my head re finished and mabe this is a great time for me to do the same.
Old 05-05-2009, 08:29 AM
kydsid's Avatar
A lot of research across forums got me about $10-$20 per injector. Witchhunter is one of the most respected shops I found and charges $18 per.
Old 05-05-2009, 09:23 AM
lofreqjeff's Avatar
There is a place down here in the Phx area that does it at $20 each:
http://www.injectorpro.com/
Old 05-05-2009, 11:29 AM
YEP, $18 per injector and $10 shipping.
I got an Email that my injectors will be shipped out today, not bad I sent them out on Friday May 1st. Order my gaskets from LC enginerring so maybe this weekend I will have the 4Runner put back together.
Old 05-05-2009, 12:11 PM
space-junk's Avatar
is it weird that im excited about this?? im in somewhat of the same situation with my truck... 19 years and im starting to wonder if thats where some of my furl mileage is going along with my slow loss of power... oh yea, and the occasional fuel smell...
Old 05-05-2009, 12:59 PM
Not wierd at all, I'm just as excited! I went from using 4th gear to get up a hill to 3rd and even 2nd in some situations and I'm aware the engine has alot of miles on it but this was riducles. I would love to rebuild the engine but its not in the cards rite know, so maybe this will bring some life back to the old girl!?!
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
WI Girl
06-25-2015 03:45 AM
Sandman
06-18-2015 11:06 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: My first time replacing injectors 88 4runner
