My $60.00 Ehxaust System!!!!!!!!!!!!!!
Old Nov 9, 2007 | 12:54 PM
mattk's Avatar
My $60.00 Exhaust System!!!!!!!!!!!!!!
First of all my truck is a 1987 4x4 X-tra cab w/206,000 miles and the 22RE motor. Took off my exhaust manifold because it had a crack in it on the downpipe. Took it to work and had my buddy weld it up for me. Also found 2 other cracks in it. Got it all welded up and decided to replace the rest of the exhaust while I had everything off. I know some of you guys are not gonna like this but I took off the cat convertor and went from the downpipe out to a Cherry Bomb Turbo muffler and straight pipe the rest of the way out with a turn down. The muffler is a 2" in/out with 2" pipe all the way. The down pipe is 2" so thats why I decided on 2" for everything. This exhaust sounds great and is not loud at all and made a noticeable difference in power. No more bogging down going up hills on the highway. Did not lose any low end and gained a little top end. I have right around $60.00 in the whole system. Some of you guys may have noticed the red RTV around the joints. I use this because of not welding the joints and using clamps this seals it all up. An old dirt bike riding trick. Let me know what you guys think!!! Check out the bigger pics on the links below!!!
http://i172.photobucket.com/albums/w...t/PB090010.jpg
http://i172.photobucket.com/albums/w...t/PB090009.jpg
http://i172.photobucket.com/albums/w...t/PB090008.jpg
http://i172.photobucket.com/albums/w...t/PB090007.jpg
http://i172.photobucket.com/albums/w...PB090006-1.jpg
http://i172.photobucket.com/albums/w...t/PB090006.jpg
Old Nov 9, 2007 | 01:59 PM
Tdubbs05's Avatar
i guess it'd be less resistance w/ a straight pipe out the back but looks like you sacrifice a some clearance. especially around the rear axle. watch out for hitting speed bumps hard.
Old Nov 9, 2007 | 02:41 PM
tampabayota's Avatar
x2^ a little too close to the rear axle in my opinon
Old Nov 9, 2007 | 02:52 PM
Luvmeye22re's Avatar
Good idea....Go buy some elbows and get that thing routed a little differently. I bet it sounds pretty good!
Old Nov 9, 2007 | 03:23 PM
Elton's Avatar
use photobucket.com for pics
Old Nov 9, 2007 | 03:49 PM
mattk's Avatar
The hangers I used keep it in place really well. The system is pretty solid and doesnt move and hit anything at all, even over bumps and stuff. Already tried it out. I will post some bigger pics on photobucket. Didnt even think about that.
Old Nov 9, 2007 | 03:54 PM
just a 22re's Avatar
bumps are nothing wait till you hit the trails then you will know if its good
Old Nov 9, 2007 | 04:12 PM
Dare44's Avatar
mine was 20 i hacked the original at the muffler put on a cherry bomb and called it good, kinda gets annoying sometimes tho
Old Nov 10, 2007 | 02:09 PM
mattk's Avatar
I dont really do much off roading with my truck but the clearance on the exhaust seems to be ok all around!!!
Old Nov 10, 2007 | 09:09 PM
Tacoma750's Avatar
probably just the picture..but it looks awful close t the driveshaft...
Old Nov 10, 2007 | 09:14 PM
fork's Avatar
holy rust batman
but nice exhaust work
Old Nov 11, 2007 | 02:46 AM
TORTIS's Avatar
beware of pirate bro. better be on your a game over their. i think they deleted your post as soon as you replied to my heads up about them. if you pm people over their they will help without the flaming and beatings.
Old Nov 11, 2007 | 03:59 AM
mattk's Avatar
Yeah I went ahead and deleted my own post. Its just the pic, its about 2" from the drive shaft. The rust looks bad but its only on the surface and not rusted through. Frame is in good shape. Gonna treat it with POR this next summer so it doesnt get bad.
Old Nov 11, 2007 | 05:08 AM
TORTIS's Avatar
wear gloves with por-15. it sticks very well to your skin.
Old Nov 11, 2007 | 05:13 AM
mattk's Avatar
Ill remember the gloves when I get to doing it
Old Nov 11, 2007 | 06:21 AM
ovrrdrive's Avatar
Looks good but you're going to eventually hit the axle on the pipe back there...
And you should think about a $5 chrome tip at the end too.
Old Nov 11, 2007 | 07:44 AM
Tacoma750's Avatar
agreed^
Old Nov 11, 2007 | 05:57 PM
gametom's Avatar
what kind of rtv did you use?
Old Nov 11, 2007 | 06:20 PM
mattk's Avatar
I used Permatex High-Temp RTV Silicone Gasket Maker # 26B. Hope that helps you out.
Old Nov 11, 2007 | 06:34 PM
WCorbett's Avatar
When you flex the drivers back tire up its gonna hit the exhuast.
