mud got me grounded.
never fried an alt because of water or mud .... been through plenty of it.
Changing your driving technique to 'save' your alternator seems a bit odd to me. Maybe its because I've never seen anyone ever have one go while in the pit.... in other words never seen mud or being submerged in water ever ruin one.
Heh no - mud / deep water and alternators (especially those that are going) don't mix... No problems since I put in a good rebuilt, but the following pictures define the death of one
Like I said, since I put in the rebuilt (pricey rebuilt, lifetime warranty) haven't had an issue...
#25
Mine has a short
My alternator's toast, in a ball of greasy oil and mud. I had it tested and Advance says that it has a short in it. Do I get a junkyard replacement or can it be rebuilt? Buying Advance's is not an option. Thanks, in advance...
#29
No, water won't kill an alternator
Today, I took my shorted out alternator to an alternator rebuilder, Chap, of Harvest, AL. He knows his stuff and has seen many more days on this earth than I can imagine. Chap said that the grease, grit, or dirt combined with the water will kill it for sure. However, water, even a fire hose spraying, on an alternator will not hurt it at all. Combine grease or dirt to the equation and you're fried! My old alternator is dead proof
My complete total for a chinese brand new alternator was $121. It's suppose to arrive tomorrow from Georgia. The Advance brand was $160 for a remanned. I'm sticking with the 60 amp and will wait to find a GM built for more power when my wallet's ready for me to and my charging system calls for it.
#30
i knew it wasnt the water. it was the muddy water. lol. well. since im grounded from driving my truck and its just sitting in the driveway, im gonna jump on it and start seeing if i cant work something out.
plans for my grounding include, some sort of protection around the alternator that will still allow airflow, some sort of air intake(suggestions would be appreciated), and a nice full body wash and wax. get my ride all purty and stuff. hehehe. going to keep it out of the mud for a while too. let the parents calm down some. they arent too keen on the fact that i wanna take my new to me '04 truck off-road. they think its an on-road truck. silly parents, tacomas are for off-road. hehehe.
#31
#32
More Info on Boyle
Hey?! Dang It, I knew I'd pay twice. Who's this Boyle you speak of and where can he be found?
#33
I've heard the "domestics" prevent mud into the engine bay by cutting up big, flat pieces of rubber/plastic stuff and fitting it around and under the engine bay, prevent too much mud from getting to your engine. Try?
#35
Anyone with a body lift should add some rubber flaps (lift lips) to cover the gap. But it all depends on how the mud/dirty water is getting to the alternator. The biggest mess in an engine bay that I've seen was from the fan blades throwing it everywhere. In that case lift lips won't stop it.
#36
Mud is bad news for the under body and engine compartment. I avoid mud whenever possible. Doing a frame-off restoration on mine has shown what a mess mud makes. It gets into the moving parts and accelerates rusting because it traps and holds water.
#37
we do have old mining area's that are pretty fun...
#38
Whatever you do, don't creep through the mud, it's not rock crawling. Momentum is your friend, and will get you further than about anything. There is a balance of course, don't fly into it.
Get used to changing the alt. FL mud kills them. I can't count the number of times I've had mine out cause the charge/brake light decided to light up on me.
I have one from Bennet auto with the lifetime warranty and they replace it every time.
Don't take off the front skid plate, it blocks alot of mud from coming up into the engine bay. Do what you can to cover up the wheel wells. Even if you just zip tie up a cardboard 12 pack box for the day, anything will help keep it out.
#39
22RE alternators
The stock alternator on the 22RE can't be beefed up, the Boyles link above shows the 3.sl0w alternator being built for more power. The other links also show 3.sl0w alternators. The 22RE requires a new bracket to be made to use a GM alternator that is capable of much more amps. Is there a plug and play 22RE alternator that is built up to give more than 60 amps? From what I've seen, the answer is nope. My fabrication skills are so weak that they don't even register on any scale. Is there anyone that sells a 22RE bracket that is pre-fabbed so that Yota techers can run the GM makes?
#40
Sure it can.
90 amp stator upgrade
That will do zero as far as mud protection though. Would be a good mod for rigs that don't get covered in the blackwater on a regular basis.
