more rear window problems.
Old 01-25-2007, 06:59 PM
gtfourdreams's Avatar
thanks to everybody who replied. after screwing around with it for an hr or so, its done. i ended up just taking it apart, putting the window up and locking the gears in place with the stuck motor. so im pretty sure the motor is dead or locked up - tried hooking it up and throwing the switch to no avail.
heres a helpful hint i learned in the process though. line the gears up in order to make it work right. and also if you do it correctly, you can stick a screw in one of the holes (to the left of where the gears line up) after the window goes all the way up to hold it in place.
woot.
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: more rear window problems.
