Mods that make others go hmmm...
Old 10-14-2008, 07:05 PM
  #81
874runner's Avatar
previous owner did this Head light mod. Has angel eye rings like a BMW, lol. What's cool about this mod is that if my light goes out I just need to replace the bulb and not the whole head light. http://img.photobucket.com/albums/v3...Picture013.jpg
same here! i looked everywhere and cant find headlights like those
Old 10-14-2008, 07:14 PM
  #82
Noltz's Avatar
Originally Posted by 86blue4runner
sweet, id love to have some info on how to do that.
TIA
MMmmmm, Electrical! I must comply . Checked it out for my '95 4R....
To add an additional controller would be pretty simple. The computer is on the left side, in the cargo area, behind the trim panels. Take your dual throw, center-off switch and connect the common pin to ground. "UP" would tap into the Red/White wire (Pic ID: #4), and "DOWN" would tap into the Green/White wire (Pic ID: #3).
If you wanted to add it into the tail gate itself, you tap into the back of the key switch. Common to White/Red (Pic ID: #1), "UP" to Red/Blue (Pic ID: #2), and "DOWN" to Green/White (Pic ID: #3).
  #83
iamsuperbleeder's Avatar
their all over eBay yall...
I even changed that little light they put in there to a green LED...
But I ditched them cause they we're not sealed right when built, as you can tell in this photo... the driver's side one is all fogged up...
I still have the composite ones that take the H4 bulbs, but I have better ones now
Old 10-14-2008, 07:20 PM
  #84
Sponsor
Tofer's Avatar
i just took the glass out, and spliced in wire at the key switch then ran it to the double throw center off switch. much easier
Old 10-15-2008, 07:45 PM
  #85
Noltz's Avatar
<Photo Removed>
Hahha!! That's option #2, in my original post I like my junk to look as factory as possible, so I figured out how to do it so you could use a factory UP/DOWN switch dremeled and glued to the cargo area wall....
Old 10-16-2008, 05:00 AM
  #86
X-AWDriver's Avatar
Hidden fuel pump switch to make sure if a thief wants my whole truck they'll have to strip it there or flatbed it but it won't be driven away.
Old 10-16-2008, 09:00 AM
  #87
86blue4runner's Avatar
sweet thanks man, this mod is soon to come along with the switch in the cargo area to turn my stereo off.
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
tpd143
07-07-2015 09:06 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Mods that make others go hmmm...
