Misfire : 3VZ
Old 11-08-2010, 12:09 PM
camo31_10.50's Avatar
Misfire : 3VZ
well as many of you know, i've rebuilt my 3vz, got around 200 miles on it i believe and it's running pretty good
i DID NOT HAVE THE INJECTORS CLEANED. but everything else was cleaned up pretty good...with the exception of forgetting to clean the upper intake manifold and i simply ran out of time to do it. there was some buildup in the manifold..but not much.
okay with that being said..here's my problem.
truck runs good until i'm out on the highway cruising 60-65 in 5th gear...punch the gas and it will accelerate "like it should" (meaning slow lol) drop down to 4th gear...and it seems like i have a cylinder misfire for a few seconds and then it stops and runs like a raped ape.
i have brand new spark plugs..but not new plug wires...but the plug wires i do have are NOT cheapo wires...they're Expensive wires..i was told the wires were prolly $60-$100 for the set.
plugs are NGK's gapped to .036 and i have my timing set at about 14*.
i also deleted my EGR system completely.
NO CEL.
i haven't tried to pull the codes yet either.
Old 11-08-2010, 02:29 PM
mattches's Avatar
Maybe crossed the egr vacuum hose to the fuel pressure regulator?
Old 11-08-2010, 07:43 PM
808-3VZE's Avatar
Check the injectors 4 sure. Hope you get it running top shape!!!
Old 11-09-2010, 12:34 PM
uhm....i honestly don't know if it's better when cold...i always let it warm up lol
i'll check my vacuum hoses again.
i don't want to have to check my injectors lol i've had my upper intake manifold off about 5 times already....don't wanna take it off again unless i have to!
Old 12-20-2010, 10:19 AM
anybody got a vacuum diagram, i'm noticing this problem more and more.
my EGR has been removed. but i can't really remember if i plugged the hoses, or wtf i did with them.
i've never been able to find a GOOD vacuum diagram...
Old 12-20-2010, 10:31 AM
James Woods's Avatar
Image Hosting
Image Hosting
Try running some seafoam in the fuel tank and hook up a can to a vacuum hose to clean the intake.
Old 12-24-2010, 09:05 AM
woo hoo! THANKS James!
pfft seafoam hasn't even crossed my mind until now, i'll run a couple cans through it soon
Old 12-24-2010, 09:07 AM
mines got quite a few more vacuum hoses than that :/
Old 12-24-2010, 10:20 AM
justin_4runner's Avatar
what holes are u wanting to know locations of???
Old 12-24-2010, 03:43 PM
oh lord, well...EVERYTHING on the passenger side of the intake manifold
i have no EGR, so i know those are plugged
Old 12-24-2010, 09:38 PM
bugs1961's Avatar
Hey there bud, Merry Christmas. This thread will tell you where they all go: https://www.yotatech.com/forums/f116.../#post51417725
This post explains where they all go, with reference to the picture in post #1. Let me know if this isn't good enough and I'll try to talk you through it. PM me for my phone number if you need to. Good luck,
Bugs
Old 12-24-2010, 09:44 PM
YOU'RE the guy that i was thinking about that told me he'd help with my vacuum lines!
THANKS
Old 12-24-2010, 09:53 PM
bugs1961's Avatar
No sweat! Have a great night and Merry Christmas.
Old 12-25-2010, 04:15 PM
Thanks Bugs you too!!!!!
after i check the vacuum lines, i believe i'll change the fuel filter, it seems to be getting a little worse everyday.
i also have a oil leak at both of my Cam Seals at the back of the heads.....i'll have to pull the motor to replace them, BUT before that, i'm going to run some Valvoline MaxLife for about 3000 miles, and see if that will help any, i've heard it has some kinda "seal swelling" additive, might slow the leak down.
Old 12-25-2010, 05:51 PM
BigGreenZ_71's Avatar
You can look at my thread, but mine was injectors. I had 3 clogged. I don't know how the truck idled so good with 3 clogged.
Old 12-31-2010, 12:32 PM
ya know, i have been noticing a bad fuel smell lately.
my first guess when that comes along....is
1. Leaking injector, probably not sealed at the fuel rail properly.
2. fuel line fitting, maybe?
and that's about it.
this could also be causing my slight misfire, correct?
Old 01-01-2011, 09:42 AM
808-3VZE's Avatar
My truck had the same problem! Had to change the fuel tank, fuel pump, fuel filer and all six fuel injectors! The inside of the tank was real bad with rust! I guess it clogged eveything up. Now it runs like a champ. So camo I hope u fix ur problem on ur rig man. Happy New Yeaar fellow Yotatechers!
Old 01-01-2011, 04:29 PM
Yep i'm in the process right now. Putting in a new tank, pump, filter, and cleaning the injectors again.
Old 01-01-2011, 05:56 PM
808-3VZE's Avatar
What happened?
Quick Reply: Misfire : 3VZ
