Marlin Crawler T-Case gears and V6 T-case - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-09-2006, 05:07 PM   #1 (permalink)
Bill's Avatar
I've been reading up on Marlin Crawler t-case gears, both the 4.70 gear sets, as well as the dual t-case set ups they offer. (ok, ok, dreaming and drooling)
However, the instal instructions are for gear driven t-cases, and for dual set-ups they say you need to use a gear driven t-case. But made no mention on use of chain drivens.
So does anyone know if you can use the same gear set with a chain driven t-case as with the gear driven cases? Or if I'd need to replace my existing case in order to get a lower crawl ratio?
__________________
86 Turbo Pickup
EB Street RV head
EB 268 Cam
V6 Brakes + MC
A340F auto ---> W56 5-spd swap
...I want a bigger turbo...
Bill is offline
Old 04-09-2006, 05:40 PM   #2 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Silly question, do you have a 5 speed or manual?
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 04-09-2006, 05:59 PM   #3 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
5speed is a manual....i think you meant Automatic or Manual lol
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 04-09-2006, 06:10 PM   #4 (permalink)
Cebby's Avatar
Quote:
Duh...ooops!
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 04-09-2006, 06:33 PM   #5 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Thats why is was a silly question
The reason you only see gear driven is because thats all you can do. The gear driven case is stronger, but not used in V6's, or 4cyl runner 90-95 since it is not shift-on-the-flyabe...Marlin makes everything you need to run a gear drive behind your v6 tranny.
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 04-09-2006, 08:41 PM   #6 (permalink)
You can only throw away the chain-driven cases. they use a planetary gear system. Marlins gears won't work with these.
JackKnife is offline
Old 04-09-2006, 11:18 PM   #7 (permalink)
Bobakazi's Avatar
Send a message via AIM to Bobakazi
Quote:
Cebby,
Respect.
That was really funny though. I think you saved yourself by saying it was a silly question.
__________________
'90 Extra cab V6 4x4 PU
5.29 gears. Detroit locker front, Detroit Truetrac rear.
35" BFG mudders. Trailmaster 4" susp, 3" body lifts. Add-a-leaf. K+N intake, 2.5" exhaust with Flowmaster 40 and a cat I got off an Evo VIII.
Bobakazi is offline
Old 04-10-2006, 12:09 AM   #8 (permalink)
kyle_22r's Avatar
the geardrive case is most certainly shiftable on the fly, provided your hubs are locked. it just doesn't have a synchro like the chain drive case.
you can adapt the gear driven case to your V6 tranny with an adapter plate and 23 spline input gear.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 04-10-2006, 06:54 AM   #9 (permalink)
Cebby's Avatar
Quote:
Originally Posted by Bobakazi
Cebby,
Respect.
That was a test. You all passed.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 04-10-2006, 08:29 AM   #10 (permalink)
abalagtas's Avatar
Send a message via Yahoo to abalagtas
There was talk on Marlin's board for a while about a chain case adapter, but it ended up being vaporware. I don't think they had the cycles to test it, but there was a lot of interest. All-in-all I don't think there was a lot of cost saving going that route.
__________________
Semper Fi,
Alfred
'91 4Runner SR5 4wd 3.0 V6
'10 Scion Xb
abalagtas is offline
Old 04-10-2006, 08:40 AM   #11 (permalink)
AH64ID's Avatar
Quote:
True, but I was going off the synchro vs non-synchro deff...
Are there trucks with ADD and Gear Drive, becuase they would have no way to shift unless stopped...
__________________
-John
AH64ID is offline
Old 04-10-2006, 09:32 AM   #12 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
so all you have to do is aquire 2 stock gear driven cases, and the lower gears, and the adater plate and diffrent input gear.
all of which will set you back a small fortune!
if you have a v6 truck and want super low gears like the "cool" rock guys, buy 1st gen with 22re and go from there... then its only $600-800 for dual cases with one set of lower gears...
see http://www.marlincrawler.com/htm/tra...ickup_dual.htm for all the drewling - eye poping goodness
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 04-10-2006, 12:43 PM   #13 (permalink)
Bill's Avatar
I've got a 5-speed...and a manual.
Where would I be able to find a t-case adapter and new input shaft? There seem to be 1st Gen's popping up every so often in the Junk yards here, so the t-case wouldn't be too too hard to find.
Two questions about going to a gear driven t-case though: 1: would using the adapter mean that it's going to be longer and therefore need a new driveshaft. 2: are (most) 1st Gen t-case top or forward shift? and what would need to be done to go from my current top-shift to a forward shift...if need be.
__________________
86 Turbo Pickup
EB Street RV head
EB 268 Cam
V6 Brakes + MC
Bill is offline
Old 04-10-2006, 09:53 PM   #14 (permalink)
kyle_22r's Avatar
i think the adapter is under an inch thick -- your slip yokes will make up that difference.
in the grand scheme of things, i'm pretty sure most cases were forward shift. ALL '79-83 cases were top shift, and other that that, only '85-88 EFI trucks had top shift cases. you can convert forward shift cases over, but the kit is about $80 from marlin. i can pick up top shift cases for that much all the time if i look.
__________________
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 04-10-2006, 09:58 PM   #15 (permalink)
Staff
The adapter is avail through all pro, marlin crawler, inchworm, advanced adapters, and a few others.
1. Yes adding an adapter will make the setup longer, and your drivelines will have to be moddified.
2. Depends on EFI or Carb (W or G series) transmissions. W series are top shift cases, G series are forward shift (w=EFI g=Carb)
You dont want a forward shift case, you want a top shift case if you are looking at dual cases.
Also, i believe turbo transfer cases are forward shift? I had to have mine converted to top shift when I did my dual cases. Forward shift cases dont work, becuase the middle case in a dual case setup only shifts high and low....no 4x4. the 4x4 part is left to the second case, which also needs to be top shift.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Marlin Crawlers 4.7 t-case gears seaflea Product Reviews 8 11-14-2008 11:45 AM
Marlin Crawler Case in new Tacos awsumdc Offroad Tech 12 06-12-2007 08:23 PM
Marlin Crawler Gears CTRJ 95.5-2004 Tacomas & 96-2002 4Runners 3 04-19-2007 04:35 AM
Marlin Crawler 4.7 21 spline t-case gear kit LEXUSBEN The Classifieds GraveYard 5 07-06-2006 09:55 AM
possible new marlin t-case! kyle_22r Offroad Tech 20 01-03-2004 06:37 AM
2009 InternetBrands, Inc.
