Major oil leak/head gasket blown
Old 04-18-2014, 10:13 PM
Mauk's Avatar
ugh, so I think my passenger side head gasket blew at 185k :rocking:
I just broke up with my gf the other day then this happens haha (I've only but about 500 miles on it or so). Its been leaking quite a but for a while now and has also been running kinda weird but well enough for a dd. so I take it in to get looked at at the mech finds that after taking to intake manifold off the valley is filled with oil, submerged the ks, and was running out the back of the engine. I like the little touch of green anti-freeze color too..
Not what i was wanting to hear but now that they know it can get fixed.
Now that they have all that crap off they see this.. who does this schit?
totally unnecessary.
Since they are in there, what would be some other things to address?
Old 04-19-2014, 02:46 AM
rworegon's Avatar
Other things: new knock sensor pigtail, water pump, timing pulleys, new timing belt, crank and cam seals, new crank bolt, new timing belt tensioner, send injectors out for cleaning, replace old coolant hoses that are now exposed.
That bolt is nasty. If they would have carefully removed the flange washer portion of the bolt they could have likely prevented a lot of the damage to the head of the bolt.
Old 04-19-2014, 12:19 PM
Mauk's Avatar
Just had the ks replaced a couple months ago.
As for the bolt they said it was like that when they got everything off
Old 04-19-2014, 01:00 PM
rworegon's Avatar
My "if they...." comment was directed at the 'mechanic' who messed it up and not necessarily at who is currently doing the work.
Old 04-19-2014, 02:13 PM
Mauk's Avatar
gotcha
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
Snort
07-19-2015 07:03 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Major oil leak/head gasket blown
