YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-04-2007, 12:29 AM   #1 (permalink)
AxleIke's Avatar
MAF Bypass?
Lots of info on how to fix these or problems with them...
For those who know about such things..
I'm looking to ditch the stock airfilter location in favor of a different area, but am running into significant issues with the MAF as it is a huge, blocky, chunk of equipment.
How much of this thing can i get rid of before i start screwing up my air mixture and throwing codes? I seriously doubt i can bypass it without messing with my economy and performance, but if someone knows a way, i'd be open to that as well.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Sponsored Links
To remove this ad, register today!
Old 02-04-2007, 12:32 AM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
its a afm not a maf
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is online now
Old 02-04-2007, 07:15 AM   #3 (permalink)
Send a message via AIM to dcg9381
Cant bypass it on a 22r-series. It's critical to airflow calculations.
Want it gone? Gotta do aftermarket EFI: SDS, FAST, Megasquirt.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 02-04-2007, 07:40 AM   #4 (permalink)
Sonofmayhem's Avatar
Mass Air Flow sensor=maf why dont you just extend your wires, get rid of the air box and put on a cone filter? i have a custom piping setup to move it next to the intake manifold. from what i see it wouldnt be hard at all just a matter of cutting and connecting the right wires.
__________________
3.4 SUPERCHARGED
Sonofmayhem is offline
Old 02-04-2007, 08:37 AM   #5 (permalink)
AxleIke's Avatar
I have a cone filter already. extending the wires is not a problem. I will just have to find a different way to route the piping than i wanted so that the MAF will fit. Thanks.
__________________
IFS SAS
AxleIke is offline
Old 02-04-2007, 08:40 AM   #6 (permalink)
As seen above, there is no MAF on the 22re.
I think there is some intake temp value for changing where you get air on the 22re.. In terms of flow, it's still got to go through the AFM.. Big pipes, small AFM hole = no difference.
__________________
dcg9381 is offline
Old 02-04-2007, 08:46 AM   #7 (permalink)
AxleIke's Avatar
It is listed as a MAF in my haynes manual, in the manual at the Toyota dealer where i get my parts, and most folks here refer to it as that.
__________________
IFS SAS
AxleIke is offline
Old 02-04-2007, 10:20 AM   #8 (permalink)
mt_goat's Avatar
Actually the FSM calls it a VAFM, volume air flow meter, but we usually call it AFM for short. It measures the air flow with a spring loaded flap, estimating the flow by volume.
After about 1996 they went to the MAF, Mass air flow meter. The MAF measures the air flow by a mass. As the air flows across the hot wire it cools down, the computer estimates the flow by how cool the wire gets.
I just saw this week a product that will replace the VAFM or the MAF completely:
http://www.yotatech.com/showthread.php?t=105832
__________________
Dale
"America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens
Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx
mt_goat is offline
Old 02-04-2007, 10:30 AM   #9 (permalink)
I'm not going to say that using that device isn't possible. I will say that every single person I know about that tried to use a piggy back with the stock AFM gave up... The signals out of the toyota AFM are very non-standard. Jeff Mosk has write up on messing with it and some decent data.
If you want to run a speed density system, run megasquirt. Build it yourself for $200 or buy it configured for the toyota for $350. My setup:
http://lakebox.dnsalias.com/photos/1...oenginein3.jpg
No AFM, it's speed density.
That's cheaper than the ECU option that is being disscussed as an option: http://www.mapecu.com/map1.html which is $399...
Also, we're talking about bucks just to get rid of the factory AFM.. On a stock or close to stock (cammed, mild porting) 22RE, it's expensive for a mild theoretical gain....
__________________
dcg9381 is offline
Old 02-04-2007, 10:49 AM   #10 (permalink)
AxleIke's Avatar
yeah, i've seen those, but its not really what i want. I just wanted to know if there was a way to get rid of the bulky unit so that i could route the air intake anywhere i wanted. Doesn't look to be possible without bucks, and i'm not interested in any performance units. add 10 hp to my 92 hp engine, and i've still only got 102. That and i don't believe it will really make any noticeable difference. Thanks though, thats what i needed to know.
__________________
IFS SAS
AxleIke is offline
Old 02-04-2007, 12:26 PM   #11 (permalink)
mt_goat's Avatar
You're probably right. I think it's one of those good news/bad news things. The good news is you can adjust the a/f ratio for max performace and get rid of that AFM restriction. The bad news is you have to make a complete fuel map for the complete rpm and pressure range from scratch, not an easy task at all for an inexperienced tuner.
__________________
Dale
mt_goat is offline
Old 02-04-2007, 02:58 PM   #12 (permalink)
AxleIke's Avatar
thanks guys. I'm not interested in screwing with all that. I'll make the stock junk work. I appreciate the info though, those sites and threads were quite informative.
__________________
IFS SAS
AxleIke is offline
Old 02-05-2007, 08:07 PM   #13 (permalink)
Toysrme's Avatar
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Quote:
Yes god forbid the AFM is restrictive...
http://www.yotatech.com/showthread.php?t=106225
__________________
AIM/Yahoo/ICQ - Toysrme257th
PM for anything, anytime; including v6 turbos!
BoostPic!
Toysrme is offline
Old 02-06-2007, 05:03 AM   #14 (permalink)
mt_goat's Avatar
Interesting, so where do you think the restrictions are? Valves?
__________________
Dale
mt_goat is offline
Old 02-06-2007, 05:59 AM   #15 (permalink)
That post was quoting a TURBO motor, not an NA motor, so it's really not a valid comparison, as the turbo is stuffing air into that motor vs pulling via vacuum.
The question is how much air can you flow past a given surface area at vacuum..
We're 146 CI, flowing (theory) about 250 cfm at 6000 RPM.
Figure out how large a TB is required to flow ~250cfm... Honestly, since the 22R doesn't produce power at 6k, we'll come in under that number.
__________________
dcg9381 is offline
Old 02-06-2007, 03:33 PM   #16 (permalink)
Toysrme's Avatar
Cool
That's a perfectly valid post.That post was concerning the larger Denso vane flap AFM loosing 3whp & less than a ft-lb of torque after having 373 horsepower worth of air SUCKED THROUGH THE AFM.......
What? You think your tiny engine pulling 1/3 the amount of air through your smaller AFM is going to respond any differently?
Build a manometer for & check it yourself if you want... Just recognize that it takes 27.68 inches of water to equal just 1 psi.
Your math is incorrect for what you need to flow. You've stopped short & not finished your math.
A 22r-e would only injest 160CFM of air @ 5000rpm, and I'd have to see a dyno of a 22r-e that ran 6000rpm to tell you that number. But 6000rpm would fall under 140CFM.
__________________
BoostPic!
Toysrme is offline
Old 02-06-2007, 03:39 PM   #17 (permalink)
BTW, we can't view the post.. Requires registration. Does the post say anything about the size of the denso AFM on that motor?
The question is: Where is the restriction in the 22re? My guess is there isn't one until you start porting the head.. Can we agree on that?
The 22RE is pulling.. One could say that a turbo motor is pushing or you could say that it pulls a lot harder based on the pressure differential. The turbo motor has a much more sigificant pressure differential. For a fixed hole size, the amount of air that goes through it is going to have something to do with the pressure or vacuum behind. More pressure = more air flow through the same hole.
I don't think my math is wrong but it was scaled from some numbers from larger displacement motors. Consider it to be a theoretical maxium (100 VE).. Definitely on the high side, I don't disagree. Most webers are rated around 200-260 cfm, if I recall correctly. I do believe the stock 22RE head generally flows like crap, maybe in the 140? Bench flow numbers on my head are over 200 cfm @ 425.
So again, what's the size of the AFM and at what flow point does it start restricting airflow?
__________________
dcg9381 is offline
Old 02-06-2007, 08:17 PM   #18 (permalink)
Targetnut's Avatar
I think the key here is to note that nothings sucks.
Pressure pushes.
With the pressure drop of a VAFM on a N/A engine you can never reach 100%VE.
A turbocharger can push air into the engine to create boost til the wastegate opens with very little change in regards to atmosphere
A very good example of this is how much atmospheric pressure (altitude) affects power output on a N/A engine as compared to a Turbocharged engine
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam, 295cc injctrs, Supra AFM, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 02-06-2007, 09:40 PM   #19 (permalink)
toyota_mdt_tech's Avatar
Quote:
Just those "not in the know", we have basically 3 systems, a AFM, MAF and a MAP systems. Thet are all different. (air flow meter, mass air flow and manifold absolute pressure)
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Yamaha WR450F
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Search this Thread:
