lubing my diffs and other chassis parts
94 3.slow runner.....tried to loosen the plug on my front and rear diffs. seems impossible to me. any suggestions? i would rather do it myself instead of paying someone
X3 of removing fill plug FIRST. Use a 6 point socket so you don't round off the plug. Make sure the socket is the correct size. Use a hammer to give the socket handle or break-over bar a couple of sharp whacks. Take your time and it will come off. They can be very tight if they have never been removed. Use same method on drain plug. No reason you can't do this yourself.
If you can't get the drain plug out (mine was seized in place), you can always buy a pump and pump the stuff out from the fill plug. It's not as effective, but it's close.
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
TokyoD23
07-12-2015 06:01 AM
