LSD in a 93 pu? How to go about
Old 09-04-2010, 10:51 AM
Wheelindealin's Avatar
Well ive looked around a lot of places and i have yet to find out how or if you can put a limited slip diff in my 93 pu. I dont want pause locked rear end i just want somthing to give me better traction but road freindly, if so wat about the front IFS, can u just leave the front gears alnone? or change them too, any help please
Old 09-04-2010, 11:01 AM
BackGateYota92's Avatar
if you change the gears in the rear you have to change the front gears to match. if you dont when you put in 4x4 you will mess alot of stuff up and if you have locking hubs up front you will not feel a front locker until you lock your hubs. alot of people say dont waste your money on limited slip but its reall up to you. im planning on lockrights front and rear on my truck
Old 09-04-2010, 11:11 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
On the cheap you can install a LSD for the front axle out of a junk yard Celica(?) and for the rear, google is your friend.
A Detroit TruTrack is a Helical gear LSD that uses no special fluids or has clutches and springs that could eventually go out.
http://www.youtube.com/watch?v=lZmsY2YvVsc
Search all the main sites like Randy's Ring and Pinion, and Summit or even EBay...
This is a PowerTrax No-Slip... I think it's marketed as the easiest to live with and limited slip-like pocket locker.
Old 09-04-2010, 12:36 PM
JamesD's Avatar
Buy the limited slip and gears if you so decide then contact this guy to install them the right way and done right the first time!!
http://www.gearinstalls.com/index.htm
James
Old 09-05-2010, 02:00 PM
ok thanks. But i shouldnt have to do anything to the front if i just change the rear to lsd right? im not changing the ratio
Old 09-05-2010, 02:04 PM
yotaman85's Avatar
if you are just installing a locker or LSD then no, you will not have to change the front.. good luck.
justdifferentials
14
06-11-2017 08:36 PM
justdifferentials
09-05-2015 06:52 PM
jaretstuff
08-04-2015 02:08 PM
coffey50
07-28-2015 10:55 AM
4runner4ever
05-08-2005 08:29 AM
Quick Reply: LSD in a 93 pu? How to go about
