Low oil pressure when warm
Old 09-25-2009, 02:12 PM
Gsull's Avatar
I have a 94 4runner (3vze) and it idle fine when cold but as soon as it gets warm the oil pressure drops and it starts to idle rough. It also aquires a small tick once it warms up. What could this be?!?!
Old 09-25-2009, 02:31 PM
MuddinRI's Avatar
Well it could be bad timing i would check that first. Low oil pressure at idle is normal for the most part ,your motor is not pushing the oil cause it's at idle. If your oil pressure is always low then i'd be worried.
Old 09-25-2009, 02:42 PM
Gsull's Avatar
Oil pressur is fine when it is cold and so is the idle but when it gets warm both of them drop.
Old 09-25-2009, 02:48 PM
MuddinRI's Avatar
timing....... do that first make sure it's right..
Old 09-25-2009, 02:54 PM
Gsull's Avatar
Hey what up! I'm from Narragansett RI!
Old 09-25-2009, 03:09 PM
Jay351's Avatar
Are you going off of your stock gauge?
If so, take those readings with a grain of salt. Mine shows decent pressure when cold but drops to 0 when warm.
always has...
Old 09-25-2009, 03:41 PM
lukeland68w's Avatar
i rebuilt my 3vz and the pressure is fine but when it gets operating temp, it goes to zero(this is a new pump and bearings). Funny(or not funny) thing is that i tried it on a manual gauge and it really drops to zero! I just start it up and drive around the block but ill tell you when it actually dies after i convert it to standard and really drive it. good luck with yours, hopefully its easy fix like a wrong gauge reading.
Old 09-25-2009, 04:11 PM
MuddinRI's Avatar
no kidding??? ya i'm in newport........ You live there now?
Old 09-25-2009, 05:27 PM
Gsull's Avatar
Mine is never at zero. The lowest it gets is about a quarter of the wAy past zero.
bigjstang
08-25-2021 12:41 AM
jbv808
08-06-2021 04:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Low oil pressure when warm
