Low Idle stalling 22re
My truck often idles really low especially when the engine hasn't warmed up yet. It will stall if it is in drive, but not park or neutral. I have changed oil, oil filter, transmission fluid, fuel filter, cleaned the egr valve, mass airflow sensor, and the throttle body recently. Only thing I was going to do in addition to all those was clean the idle air control valve, but the screws were on too tight for the crappy screwdriver I was using.
I have the screw that controls the idle almost all the way loosened.
The idling isn't too much of a problem once it is warmed up, but I can tell that it could be better.
Any other things I could do or check??? (I know stuff like the atf has nothing to do with idling just mentioning it)
