Loud ticking on warm up and in gear - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-28-2007, 02:26 PM   #1 (permalink)
Hey guys, I have a 91 4runner, 5 speed 22re. I have an interesting problem. If I were to start my car after a night of rest so completely cold engine it sounds fine. Sounds like a normal purring engine. However if I were to put it into gear say 1st and accelerate I get a ticking thats really loud and gets louder and more repititous as I accelerate to higher rpms, however it goes away after a warm up period and also goes away if I were to lower rpms (not as loud basically). This doesn't seem to affect performance in any way that I know of, and the engine is relatively new in terms of miles, perhaps 10,000 miles since complete rebuild. So any ideas? My guesses are either my valve train just needs to be readjusted since it hasn't happened since rebuild or that its piston slap... I have heard that its common on the 22res and goes away with warm up. I am just confused why it only happens when I am in gear, does the add torque to the engine cause the noise? Thanks guys I'd appreciate any ideas.
L33mur is offline
Old 11-29-2007, 01:01 AM   #2 (permalink)
bump!
L33mur is offline
Old 11-29-2007, 02:36 AM   #3 (permalink)
idanity's Avatar
it may throw off the balance of the engine.
and perhaps your timing chain is in need of replacement (they wear through into the block).
can you pinpoint the noise w/a stethoscope or long driver ?
idanity is offline
Old 11-29-2007, 04:27 AM   #4 (permalink)
could also be a small exhaust leak.
i had a similar issue, only it happened all the time under load, but i couldn't get it to happen while just sitting there so it was hard to pinpoint and i tried everything.
finally ended up being a bad exhaust manifold gasket.
my thought on yours is that it could be a crack in the manifold that heats up when warm, and seals off. that's fairly typical for a small exhaust leak
MMA_Alex is offline
Old 11-29-2007, 09:34 PM   #5 (permalink)
Umm I can't really pinpoint it cause it only really happens while driving and taking a stethascope to a running engine sounds scary to me lol, but what MMA_Alex said seems to make some sense, exhaust is kind of rusted perhaps I have a leak in the manifold, I am not sure how to test for that though? I mean wouldn't it make sense that if I reved the engine up without it being in gear that I should hear that noise. And the timing chain, well i hope its not that because thats not going to be a fun fix, thanks guys i appreciate the ideas a lot
L33mur is offline
Old 11-29-2007, 09:40 PM   #6 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
only happens when driving it cold? let her warm up.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 11-30-2007, 07:50 AM   #7 (permalink)
well go ahead and pull the valve cover to check the chain. its just the vacuum hoses, and a couple of 12mm nuts, and it'll come right off. you can check the condition of the chain, and guides.
as far as the exhaust leak goes mine was actually audible without being in gear, but you had to have your head right by it. it was only audible in the cab when in gear.
if you find a good mechanic they'll usually figure out whats wrong, and quote you a price for free, and they have a much better ear for these things.
MMA_Alex is offline
Old 11-30-2007, 08:00 AM   #8 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Quote:
Yes, it does seem as though the added torque is exaggerating the issue.
It kind of sounds like the timing chain given the symptoms, but I would hope that was replaced during the rebuild. Unless it was just installed incorrectly or it was a junk chain kit (as in defective or just very poor quality), it seems unlikely to be the problem. You could always pull the valve cover and check.
The valves make more sense, though...either out of adjustment or an exhaust leak. If they've not been adjusted in a while, you could check them at the same time you inspect the timing chain.
For the exhaust, you could spray some soapy water (Dawn works good...nice and sudsy) around the gasket and O2 sensor (not on it). You would likely have a power loss were there a leak, though. Plus, you should have a new gasket from the rebuild. However, the studs/bolts can loosen up after a servicing.
Check it all. The stethoscope would be a good idea....would save you from having to take anything apart immediately. That or a long screwdriver or narrow piece of pipe/tube.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How hot/warm should the 2 gear shifter levers get? retiring2texas Newbie Tech Section 4 11-12-2007 03:30 PM
loud engine ticking CGOULET 86-95 Trucks & 4Runners 1 05-18-2006 10:11 AM
It's not warm here. oly884 Off Topic Talk 26 12-08-2005 02:00 PM
Are your valves ticking now that it's warm? 4RUNR Maintenance & Repair Archives 7 06-27-2005 12:50 PM
Warm up..? az4x4runner 95.5-2004 Tacomas & 96-2002 4Runners 19 12-10-2002 11:23 PM
2009 InternetBrands, Inc.
