Loosing Oil??
Old 01-17-2010, 09:23 AM
MuddinRI's Avatar
Angry Loosing Oil??
Ok been awhile since i've been on, just bought a house with a nice big garage yippi!!! So that's my excuse lol... Ok so i've got 3k on my fresh rebuild and i'm noticing it's going through oil like crazy.... Can't find a leak anywhere, nothing in the coolant, and it seems to right well. I'm loosing like 1 1/2 -2 qts. every 200-300 miles. I've got no idea where it's going.... There is no blue or black smoke at anytime no leak i'm stumped... Any suggestion would be great.... thanks
Old 01-17-2010, 09:35 AM
myyota's Avatar
What kind of oil are you using ?.
Old 01-17-2010, 09:36 AM
MuddinRI's Avatar
5/30 gtx. till like 6k then i want to switch to synthetic. need to fix the oil issue 1st.
Old 01-17-2010, 09:41 AM
Plumbrbob's Avatar
you must be burning it do a compression test
Old 01-17-2010, 09:49 AM
MuddinRI's Avatar
No i need to get a tester and do that... Been so busy moving and all the bs that comes with buying a house that is almost 100 yrs old.... Also planning my wedding in Costa Rica in 2 wks been a crazy yr... just finally got some stuff moved around in the garage i can actually pull my trucks in now..keep the suggestions coming i'll be messing with it this wk i hope.
Old 01-17-2010, 09:59 AM
myyota's Avatar
I would guess that your rings havn`t seated yet, your also using a thin oil, i would try using 10w30 motor oil and see if that helps.
Old 01-17-2010, 10:04 AM
MuddinRI's Avatar
Really don't they seat fairly quickly? what do i know it's my 1st build.... Well i'll try it want to get this thing perfecto before i move on to a new project.
Old 01-17-2010, 10:11 AM
myyota's Avatar
It can take anywere from 3000 to 6000 miles for the rings to completely seat, don`t be afraid to drive it a little bit hard to help the rings seat, you won`t hurt it.
Old 01-17-2010, 10:43 AM
MuddinRI's Avatar
Cool ty.. does it really burn that much in that short of time? I drove to ME about a 300 mile trip and burned 2 qt each way seems like a lot to me but dunno...
Old 01-17-2010, 11:00 AM
myyota's Avatar
It can. If the oil problem doesn`t stop by 5000 miles or so, then you might have a problem that will require tearing the engine down again. But before you do you might try doing a leak down test and that should tell you wich cylinder is giving you problems.
Old 01-17-2010, 11:12 AM
MuddinRI's Avatar
I hear ppl talk about the leak down test but never get any info on how to do it.... Can you tell me how to go about doing a leak down?
Old 01-17-2010, 11:51 AM
myyota's Avatar
I don`t know that much about it either, but from what i understand its a test to see how long or how well a cylinder will hold presure and with that they can tell that there is a problem in a particular cylinder, its could be bad rings bad valves or a cracked head.
Old 01-17-2010, 01:35 PM
MuddinRI's Avatar
Ok if you or anyone else knows or comes a cross a thread on leakdown testing let me know ty...
Old 01-17-2010, 02:48 PM
Teuf's Avatar
whatever you do stay with the 5/30, oil does not disappear because its 5W
Old 01-18-2010, 12:18 PM
MuddinRI's Avatar
Why do i need to stay with 5 30? you can run up to 15 40 in these trucks...
Old 01-18-2010, 12:42 PM
ibeamtaco's Avatar
hey while you are braking it in don't Cruz at steady speed not good for brake you don't want to hold rpms and it will take sometimes up 2 8000k to brake in and keep a good eye on fluid levels
Old 01-18-2010, 12:51 PM
MuddinRI's Avatar
Well that's my problem i'm loosing oil..... Got no leaks and no smoke???...... I do run on highway a lot.. Broke it for the 1st 500 limited highway. Dunno what the deal is but it seems to go through oil like a pig...
Old 01-18-2010, 01:00 PM
Teuf's Avatar
15 w is to thick for start ups. I wouldn't use it. Remember a large percentage of wear is on start ups, go thin. I just changed to 5/30 syn blend, then later prob to all syn.
Old 01-18-2010, 01:42 PM
Reedr125's Avatar
I always heard that if it doesn't burn at least a quart a week its not fast enough! Sounds like yours is super fast LOL jk. Did you check the radiator and resevoir? I can see a motor burning some but that sounds like excessive. Do you ever smell burning oil even though theres no smoke?
Old 01-18-2010, 02:55 PM
Matt90V6SR5's Avatar
Loosing oil?...oh you mean losing oil,lol.
Quick Reply: Loosing Oil??
