looking for a second opinion on trany problems
Old 01-22-2008, 06:48 PM
zero51flatland's Avatar
Hey, i have an '87 4 runner, has about 250,000 miles and i belive im having the start of a trany failure. i go wealing often and my truck is starting to act unusual downshifting or slowing down in second and now third gear.
when downshifting in 2nd of 3rd my truck begins to violantly shake i thought out of tiers out of allignment but if im out of gear it as smoth as silk stoping from the front end it feel to b the steering begins to go nuts. i thought of everythign i could i thought bend my front axel, thought about shot bearing, shattered clutch, broken motor mount but it only happens while in second or third gear downshifting. i get a tiny bit of vibratrion accelerating but as long as i can remember it done that forever but only in 2nd 15- 25 mph. i rebuilt the motor about 50,000 miles ago, i have the 22rec, i have 35 by 12.5, with 5.29 grears and detroit truetrack diffs, 4in skyjacer lift in front and 6" longtravels in the rear. anyother ideas? Do u guys think gearbox too??
thanks for your help
Old 01-22-2008, 08:54 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Are you having trouble shifting? Does it grind at all?
Old 01-22-2008, 09:12 PM
CJM
CJM's Avatar
WHats the fluid look like?
Old 01-22-2008, 09:26 PM
TNRabbit's Avatar
You have a universal joint going bad. Check it out.
Old 01-22-2008, 10:21 PM
thook's Avatar
That's what it sounds like to me, too.
Usually what starts going bad in the transmissions first is the brass synchronizers with associated problems of shifting gears......coincidentally in the 2nd and 3rd gears. However, those problems can also be related to shifter seat bushing or even the type of gear oil.
Old 01-23-2008, 01:05 AM
80W90's Avatar
that or its from a chattering clutch.
all that wheelin will kill your clutch.
Old 01-24-2008, 07:21 PM
the fluid looks good changed when i changed my differentials no problems grinding through gears and if my clutch is chatering why doesent it do the same thing downing to my other gears? thanks for the help
Old 01-24-2008, 08:28 PM
80W90's Avatar
perhaps the increased torque of downshifting makes it chatter.
50k, and wheelin a lot will kill your clutch.
dumpster84
04-30-2016 06:03 AM
kirkrunner
07-27-2015 07:59 PM
britishdudes2dr
07-25-2015 06:47 AM
nonstop
07-24-2015 06:29 PM
A2theK
07-12-2015 10:46 AM
Quick Reply: looking for a second opinion on trany problems
