Light bar questions
Old 11-13-2015, 10:08 AM
9322rerunner's Avatar
Light bar questions
So I am buying a light bar here within the next few days. Ordered my zombie light switch and will be ordering a 30" light bar. Now I am thinking of mounting it in the lower valance where it opens up in the middle. Is that a good spot for it? Will it block any air flow to the radiator? If anyone has any other suggestions, please feel free to do so, I am not opposed to doing LED pod lights as well if that's a better idea and someone has better suggestions for mounting those.
Old 11-14-2015, 06:07 PM
Anybody?
Old 11-14-2015, 10:35 PM
Robert m's Avatar
Mine is a 2wd so it has a little different front end setup but I put a 30'' bar on my old stock front bumper. Had no cooling issues with it like this and as long as your cooling system is in good shape, you shouldn't either.
The thing with off road lights is you want them mounted as high as possible to throw more light down the way and to create less shadows on the trail. The down side to that is if you mount it too high, like above the windshield like a lot of people are doing, then you get blinded by the reflection off the hood which only gets worse if you get into someones dust.
Old 11-15-2015, 08:02 AM
Fossilized
Staff
dropzone's Avatar
Mounted down below will impact some air flow to your radiator but impact should be minimal if your cooling system is in good shape.
Old 11-15-2015, 10:07 AM
That looks awesome! I don't want to mount the light bar high because right now while replacing some suspension components and various other things, she's an onroad rig, as soon as the body lift comes off and the OME lift goes on and my new tie rods are on, I'm buying a roof basket and going to be getting some pods. So ideally the bar is for the street driving because the stock headlights are junk.
As far as airflow, my cooling system is in pretty good shape, I will be replacing my radiator Saturday as it leaks a bit, but other than that, everything else is good.
Old 11-15-2015, 11:19 AM
Fossilized
Staff
dropzone's Avatar
If you can swing it I would get the curved bar.
Old 11-15-2015, 01:22 PM
Should I do that because it distributes the light better?
Old 11-19-2015, 08:50 AM
Brock Lee's Avatar
I know those LED lightbars are expensive. Aren't you worried about rocks damaging that thing?
PS - You should think about replacing that swirled license plate. That's a mess. :-)
Old 11-19-2015, 10:04 AM
Robert m's Avatar
Nope, not worried. The lenses on most (if not all) the good bars are not glass, they are polycarbonate. So it would take a big rock hit to do any real damage.
Old 12-15-2015, 10:14 PM
Corey_Jewell's Avatar
Howdy everyone, new member here! Not to bring up an older thread but figured I'd show where I've mounted my 30inch light bar from TSC, got it on black Friday
EFI85
11-13-2015 12:14 PM
jhsantacruz63
10-22-2015 01:03 PM
yotapwru
Washington
10-22-2015 09:08 AM
vandert
10-18-2015 07:37 PM
Toyowner_
10-16-2015 01:33 PM
Quick Reply: Light bar questions
