Lift & Tires Question
Old 01-13-2008, 12:28 PM
orbital02's Avatar
Hey guys. I thinking about possibly lifting and/or running bigger tires. I've already read a lot of treads about what some of you guys have done, but I have a diff. case. My 4runner has rust along every wheel well and the back tailgate. I am already planning on painting my truck using the "$100 paint job" technique some people have done. So my question is.... since I'm planning on cutting the wheel wells out, should I not lift it if I plan on running 31's or 33's? I realize I have to re-gear for 33's. I plan on cutting about 2-3" off the wheel wells. One more thing to consider is I already have a set of chevy 15x8 rims for future tires. Im currently running stock sr5 wheels/snow tire combo.
Old 01-13-2008, 12:35 PM
Jay351's Avatar
first of all, you can run a 31x10.50" stock, most trucks came with that combo from the factory.
You can run up to a 33x10.50 on the stock rim ( or one close to it) with only minor inner fender trimming.
Old 01-13-2008, 01:33 PM
orbital02's Avatar
Yeah, sorry... I know I can run 31's stock. I guess I meant to say wouldn't it look stupid if I ran anything less than 31 or 32" tires with fender trimming?
Old 01-13-2008, 03:06 PM
Jay351's Avatar
Depends on the person I guess. If your rims were a little wider it would look okay.
Old 01-13-2008, 08:23 PM
tc
tc's Avatar
Heck, if you're gonna cut 1-2" out, you could run 35's...
http://www.trailslesstraveled.com/ar...4e7e837c7a7d06
Old 01-13-2008, 08:28 PM
GatorTaco's Avatar
Haha, I was waiting for somebody to post that up. I wish i had the ability to cut my truck up. I'll just dream for now
Old 01-13-2008, 08:55 PM
shancerlelby's Avatar
"I have a diff. case. My 4runner has rust along every wheel well and the back tailgate." sounds like most 4 runners to me. but yea 35's with cut fender wells has been done to success with no lift. but then most rigs like that dont mind alittle bit of rubbing either way.
Old 01-13-2008, 08:59 PM
AxleIke's Avatar
I'm pretty sure you need a SAS.
Weld both diffs.
Put on whatever tire size you need, and add lift blocks until you don't rub.
Old 01-14-2008, 06:53 AM
tc
tc's Avatar
You forgot a smiley (or 6) in your post Isaac.
Someone might think you're serious.
Old 01-14-2008, 07:15 AM
Tacoclimber's Avatar
I thought the same thing. There are a few I can think of who might run out and do something along those lines...
Old 01-14-2008, 07:33 AM
AxleIke's Avatar
Well, okay.
Its just my new standard response when questions are asked that have been asked 10000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000 times before. When one hits "New Posts" this thread was found 3 threads down from another "what tire size fits" thread, and on the other 2 pages there were at least 3 more.
Also, its probably what he'll be doing anyway, as that is essentially the internet wisdom. I've talked lockers and gears till my face was blue, and its still lift, tires, and SAS.
Here are the smileys
Old 01-14-2008, 07:38 AM
Originally Posted by AxleIke
Well, okay.
In a feeble attempt to encourage you, there are those of us who really do wish we would have done it the right way to begin with. If I could go back, I would have invested in gears long before a lift. Now that the money tree is pretty much bare, I am forced to make do.
So, lift up your head my friend and be encouraged, your words of wisdom have not gone completely unheeded...
CanTheWhales's Avatar
Alright, to answer the OP's question:
In your situation 33's will barely rub on the inner fender and 35's will hit just about everywhere, but they will "fit".
If you actually read the article (not implying you didn't, that was worded wrong) it says that there's more to bigger tire than just lifting to fit, they need to fit at full compression, so trimming your fenders, will maybe allow 35's to fit and turn on level ground , but the only place you will be able to steer at full stuff will be straight 'cause they'll be wedged up in there pretty good.
Hope this helps, just trying to point out things to consider...
Old 01-14-2008, 10:07 AM
tc
tc's Avatar
Isaac doesn't have any friends. I mean, he does for a short while, but then they spend all this money on lift, tires, and SAS and can't afford to wheel or even go out, and when they do, his "little" IFS truck runs circles around them ... very slowly.
Old 01-14-2008, 11:23 AM
AxleIke's Avatar
LOL
Yeah, thats true.
Anyway, hope the OP finds the answers he seeks.
Old 01-14-2008, 11:38 AM
I just sprayed coffee...
Old 01-14-2008, 11:51 AM
Djlarroc's Avatar
To the OP: If you're going to cut your fenders, don't spend a dime on lift. Get some 33x12.50's on those 15x8s.
To Isaac (& TC), your knowledge and advice have struck me too. I spent a whole $25 on a 1" Body lift, sold the huge 33x13.50 LTBs I originally bought, and spent my money on an e-locker, front truetrac, regear, sliders, BJ spacers (for travel) & 31" MTs. Still trying to finish installing all these mods, but I think I will be very happy!
Old 01-14-2008, 12:21 PM
AxleIke's Avatar
You will be.
Old 01-15-2008, 11:02 AM
orbital02's Avatar
thanks for all of your suggestions... I think Ill probably go with 33's, gears and a locker. Btw.... what does OP mean?
Old 01-15-2008, 11:12 AM
tc
tc's Avatar
OP = original poster (the one who started the thread)
Quick Reply: Lift & Tires Question
