Knock sensors
No I understand that it will run better with one. I know that I cant set timing, or any of that. Thats not what Im saying. I expect it to run 110% better than it does now. I havent had the chance to get one. I should be able to Monday. What my concern was, how is not setting a cel. But that mystrey has also been solved.
Was it not setting CEL because of a seperate wiring issue? If so what did you do. My dads p/u 22RE would not show the CEL when you would switch the vehicle on, but it would crank but not start. I can't remember what the fix was.
1uzRunner
63
11-10-2018 03:58 PM
