key wont turn. how do i remove ignition?
Old 03-06-2009, 11:52 AM
87toyy's Avatar
went to go to work this morning and my key wouldnt turn in the ignition i figured it was froze cause it was minus 20 this morning. anyways got home form work today and still wont turn its not froze you can feel something keeping it from turning. how do you remove the ignition so i can check it out or replace it?
Old 03-06-2009, 12:14 PM
84RNR's Avatar
Is your steering wheel straight and not a little turned and locked? With the ignition off, if you turn the wheel a little it locks and it makes it hard or impossible to turn the ignition without turning the wheel a little. If that's not it, sorry I have no idea.
Old 03-06-2009, 12:28 PM
rock slayer's Avatar
sawzall?!?!? hahahhaha try turning the steering wheel back and forth while turning the key
and in order to get that out you need the key in the acc position soo if the first suggestion doesn't work than sorry but i 2 dont know
Old 03-06-2009, 12:29 PM
87toyy's Avatar
the steering wheel is locked now after i turned it all the way to the left when i was moving it back and forth but wasnt locked and was straight and the key still wouldnt move.
Old 03-06-2009, 12:35 PM
try pushing the key in and up when your turning it that worked in my old truck
Old 03-06-2009, 12:37 PM
did you take off the plastec around the ignition?? maybe something cought?!?!
Old 03-06-2009, 12:40 PM
87toyy's Avatar
i've tried everything i can think off with the key and steering wheel and nothing worked. so theres no way to get it out unless its in the acc position? i think i'm screwed then. i can start it by turning the piece with the wires that goes in the bottom of the ignition. is there anyway to unlock the wheel?
Old 03-06-2009, 12:44 PM
not without breaking the steering lock i dont think
Old 03-06-2009, 12:46 PM
what if you align the "piece with the wires that goes in the bottom of the ignition" with the ignition switch back to where they should be???
Old 03-06-2009, 12:52 PM
87toyy's Avatar
they are lined up and pretty sure they are in the right spot
Old 03-06-2009, 01:20 PM
huh?!?!? yeah i dont know... the steering lock is weak and can be broken with a big flathead screwdriver it literally breaks it tho so i would NOT recommend it but if you have an emergency and NEED to then thats how you do it
Old 03-06-2009, 01:52 PM
toyota4x4907's Avatar
Dude dude dude dude...I had the same problem when it was -40 and colder here in January..... Heres what I did and it worked everytime
Get a lighter and a key (that works for the truck) that you don't care about too much.
1) Heat the key until it is hot to the touch
2) Put the key in the ignition and let it sit
3) If you can, use the lighter the heat the ignition cylinder itself (there was a plastic cover around the cylinder on my '93 that was removable, but not on my '88, so it may be different)
4) Take the key out and heat it again
5) Put it back in and try to turn it while jerking he steering wheel the other way.
It worked for me every time...but you might not get the same results.Its worth a try though
Old 03-06-2009, 01:56 PM
87toyy's Avatar
i tried heating the key this morning with no luck. it turned mild after work so i really dont think its froze. it feels like there is something stoping it.
Old 03-06-2009, 02:06 PM
Heat it more? can you get a lighter under/around the ignition cylinder itself?
Old 03-06-2009, 02:25 PM
87toyy's Avatar
yeah i can get a lighter on it,but like i said i really dont think its froze when it was plus 10 this afternoon it should have thawed out if it was.
Old 03-06-2009, 03:48 PM
84RNR's Avatar
Sorry bro, I have no idea how to get the ignition cylinder out, since other ways to get it unstuck haven't worked. Hopefully someone else will see this who had the same problem.
Old 03-06-2009, 03:57 PM
75k5toy's Avatar
Remove the plastic cover, on the top of the ignition housing is a pin, when you put the ignition on the acc. Position this pin goes down really easy...now. Since you have no key, you push that pin down, it will go like half way down, while pushing the pin, get a thin flat screwdriver and pry the ignition out, is kind of hard but posible, all you need is patience, done this way like 3 times. Good luck.
Old 03-07-2009, 03:46 AM
87toyy's Avatar
the only thing on the top of the ignition that i think u might be talking about is the button to turn the key from acc to lock when u shut it off. if that it it doesnt want to push down very far at all seems stuck too.
Old 03-07-2009, 11:40 AM
87toyy's Avatar
i finally messed with the key all day and got it turning. i put it to the acc and took it out. i found 2 ignition cylinders but they are different where the pin is located to pop them out. i'm guessing i would need one form an 87 or older?since both of these were from 88's.
Old 03-07-2009, 12:15 PM
Cwake's Avatar
Your current key is probably old and worn? If so, just get a new key cut from it. Problem solved...
Do you usually have to jiggle the key a bit to get it to turn? If the teeth on your keys are worn down enough the key won't work anymore. From my experience anyways..
theking11863
03-19-2016 09:36 PM
redneck17
08-05-2015 10:03 AM
TDonkey
07-26-2015 10:14 AM
luckypig44
07-19-2015 11:25 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: key wont turn. how do i remove ignition?
