Intake Manifold pics
Old 03-27-2009, 08:49 AM
scuba#1's Avatar
Hi there,
I'm doing a head gasket replacement on a 3.0 and I was just wondering if other people's intake manifold had the same kind of gunk in the chambers that mine does? If so is it just leftovers from the EGR system? Or does it mean trouble?
P.S. notice how the rear chambers of the manifold are clean where the gasket blew!
Attached Thumbnails Intake Manifold pics-p1010107.jpg   Intake Manifold pics-p1010128.jpg
Old 03-27-2009, 08:52 AM
Staff
DeathCougar's Avatar
It is a combo of things, but mostly EGR issues. Its relatively easy to clean, just take some brake clean to it OR, take it to a machine shop. They will usually toss them in a clamshell cleaner for about $10-$20 or so.
Old 03-27-2009, 09:03 AM
scuba#1's Avatar
Is it bad? Does it mean I need a new EGR valve and modulator filter?
Old 03-27-2009, 10:26 AM
Wheelingnoob's Avatar
Its very common on all engines with EGR valves, its a combination of the EGR and the PCV systems. If you have it apart clean it up with carb cleaner or Brake clean. Also check the back side of the throttle body.
Jeremy
Old 03-27-2009, 10:35 AM
DupermanDave's Avatar
I'd clean it. Consider how long you've had the truck running. How many miles it has on it. And this is all that's built up after that long.
Stick it in the dishwasher, and then use parts cleaner on what doesn't come clean. Okay, dishwasher ideas isn't the best idea. Just stick with the parts cleaner.
Old 03-27-2009, 12:20 PM
scuba#1's Avatar
Thanks you guys! I just got in from cleaning the manifold. I think everything will be sweet!!!
Old 03-27-2009, 01:15 PM
iamsuperbleeder's Avatar
wow, I knew that was notorious with the 22re's, but I didn't know the 3.0's suffered from it to...
I already tackled the task a while ago of removing my manifold just to clean that junk out... 290k thousand miles plus a bad O2 sencor that makes the fuel mixture rich speeds up that build-up proccess
Blamalam
03-12-2022 07:34 AM
ksmudrunner99
08-07-2015 06:46 PM
Flossy
08-05-2015 05:14 PM
whereAreMyPants
07-22-2015 03:32 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Intake Manifold pics
