Installing Aussie in IFS, HELP!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2009, 08:26 PM   #1 (permalink)
r2m
I did an Aussie lunchbox install in the rear 8" on my 89 PU yesterday, not bad. First time I've ever been in a dif.
Now I'm installing the front.
I have the left front rotor off, drive shaft off and drained the oil.
BUT: How does one move the axles out to remove the 3rd???
Am I doing it right? Or is there another way to be able to slide the axles out a couple of inches?
I have looked/googled/yota'ed everywhere for info for how to install an Aussie locker in a Toy IFS and there's just nothing out there.
And I really need to get this going, it's my daily driver.
Help me. I've fallen and I can't get up......
Also, where can I get one of them 54mm sockets for the front axle? I had to use....
nevermind, and the nuts arn't damaged, but the right tool would have helped!
Thanks in advance for any and all assistance!!!
r2m is offline
Old 11-08-2009, 08:34 PM   #2 (permalink)
peow130's Avatar
You don't need to do all that..
Unbolt the CV's from the front diff, and unbolt the 3 bolts on the differential to drop it.
Don't forget the 4 bolts for the front driveline.
To remove the CV's from the hubs, you'll need to remove the hub face, and a gold bolt on the inside of the hub...
You don't have to take off the rotor lol.
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5
1978 Camaro Z28, 454 Big Block V8 with a 4 Speed.
peow130 is offline
Old 11-08-2009, 08:39 PM   #3 (permalink)
88Cleve4runner's Avatar
yeah if all you're doing is taking your front third out to lock it, you have 4 bolts to take off the dshaft, 12 total bolts for the cv's, 1 bolt in front of the diff, 2 bolts above diff. you don't have to take your cv's off to take your front diff out. then take off the front cover and you're in.
while its out, go ahead and take out your studs that hold your cv's in and replace them with nuts and bolts. super easier way to change a cv off road.
__________________
88 4runner-22RE, 5sp, 33x12.50 bighorns, ARB front locker, Aussie Rear locker, sliders, rear bumper, skids, Chevy 63's,2 hella 500's
98 4runner- 3.4 auto, stocker DD
my profile- http://www.yotatech.com/f77/my-profi.../#post51044313
88Cleve4runner is offline
Old 11-08-2009, 08:45 PM   #4 (permalink)
drew303's Avatar
What they all said. Maybe when you have everything out, bust out the torch and snarf all the IFS Crapola out from there and weld in a hangar, some frame jigs, hang some springs and a 85 trussed axle under there
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 11-08-2009, 08:54 PM   #5 (permalink)
peow130's Avatar
it's easier to put the front diff back in without the CV's in.. then you can slip the CV's in after it's all done..
__________________
peow130 is offline
Old 11-08-2009, 09:06 PM   #6 (permalink)
89silverpu's Avatar
Quote:
He's not saying put the front diff back in with the cv's attached, hes saying knock out the studs (or grind the splines down) so they slide in and out so you only have to take the hub assembly apart to get the CV out if you break it wheelin. After doing this, it will slide down through the LCA.
__________________
'89 Beater in progress
4.88's, TRD e-locker, Dual Cases, 33's, Armored,
Tread Lightly
Mixchallenge.info
89silverpu is offline
Old 11-08-2009, 09:08 PM   #7 (permalink)
89silverpu's Avatar
Oh, and this should help:
http://gearinstalls.com/ifs.htm
__________________
Tread Lightly
Mixchallenge.info
Old 11-08-2009, 09:28 PM   #8 (permalink)
peow130's Avatar
Quote:
"you don't have to take your cv's off to take your front diff out."
With the CV's in it's a pita to get it lined up correctly..
But if you take the studs out then it's np.
__________________
peow130 is offline
Old 11-08-2009, 09:47 PM   #9 (permalink)
Stuwy123's Avatar
Don't grind the splines off the CV bolts!!! The splines spot the bolts from loosening off.
Remember to use a nut on the bolts when you pound them out of the CV's.
Stuwy123 is offline
Old 11-08-2009, 09:54 PM   #10 (permalink)
peow130's Avatar
if you're taking the studs out, and replacing them with new grade 8 bolts, then it doesn't really matter if you grind them down, lol.
__________________
peow130 is offline
Old 11-08-2009, 09:59 PM   #11 (permalink)
89silverpu's Avatar
I ground mine down and have had zero problems with them loosening.
__________________
Tread Lightly
Mixchallenge.info
Old 11-08-2009, 10:05 PM   #12 (permalink)
TOYOTA 1's Avatar
why even take the studs out?
its easy to swap a 3rd out, and it only takes like 30 minutes. i guess it would make it easier though
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 11-08-2009, 10:05 PM   #13 (permalink)
Wabfab.org sells the 54mm sockets (3/8" drive). So does Marlincrawler.com (1/2" drive).
__________________
1986 22R 4X4 pickup. Currently rebuilding the engine.
flyingbrass is offline
Old 11-08-2009, 11:09 PM   #14 (permalink)
peow130's Avatar
because when you go to put a CV back in, it's a serious pita to maneuver it through those studs, lol..
__________________
peow130 is offline
Old 11-09-2009, 08:10 AM   #15 (permalink)
r2m
Been to Zuk's site and there is nothing relating to what is necessary to to get to the point so one can slip out the 3rd.
Albeit, this site was handy for the rear install! Didn't need any grease for holding the pins and springs in, just for the face-to-face.
Thanks for the input!
OOPS!!!!!!!
My bad, I should have gone to the link "gearinstalls.com" that you had posted. It DOES have a thorough removal of the front dif.
I humbly apologize 89silverpu....
r2m is offline
Tags
87, axle, cv, front, ifs, install, lift, locker, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
