installed clutch in neutral
Ok, I hope I didn't mess up. i installed the clutch in neutral today and I used the alignment tool. When braking the bolts around the pressure plate loose, the entire flywheel turned with me. When I tightened the bolt's the flywheel also turned. Will this cause a problem when lining the tranny back up?
yeah your fine
when you go to line the trans back up, just put it in 1st gear, and wiggle the drive shaft as your mating the trans to the motor, and everything should lock in fine
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
