Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
injector wiring 1988 22re
ok i have replaced the head with a new head the other two had too much shaved off one had .040 and the other had .050 shaved off .when i was putting the head back on washed thr engine compartment down and washed the tags off the injector wiring the manual i have does not giveme any help with the wire numbers doe sany one out there have the wire numbers so im not guessing witch one goes were .
| Sponsored Links |
#2 (permalink) |
it should be pretty much self explanatory, the injector wires are only long enough to go on one way, the shortest one goes to #1 the next shortest one goes to #2 and so on, at least thats how it is on my '86 harness
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 4300k Philips bulbs |
#3 (permalink) |
It is not extremely important wherre each plug goes since the 22re is a batch fire motor. All of the injectors get grounded and fire at the same time. However like said above, its obvious to see which plug goes to which injector by their length out of the harness (at least it was in my case).
__________________
'87 4-Runner w/ a 22re and some stuff... |
#4 (permalink) |
Actually i think that they fire in pairs, so if you had 1&3 firing at the same time youd be good, but not if 1&2 were. if you get my point,
wade
__________________
86 runner, rebuilt motor, egr block off, headman header, 3"bl, 33x12.5 m/t's. Lots of work wanted to do. limited skills, funds, time and drive. If you dont know where your going, anyplace will do..... |
#5 (permalink) | |
Quote:
1 & 3 can be interchanged as well as 2 & 4, but it'll be hard to do that because the length of 1 won't reach to 3.
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How can I test injector wiring harness | Lifelongtoy | 86-95 Trucks & 4Runners | 11 | 07-11-2007 12:32 PM |
| 1988 22RE to be scrapped | chopitrakeit | 86-95 Trucks & 4Runners | 7 | 05-03-2007 06:53 AM |
| 1988 22re swap with a 1988 V6 3.0 | bginaz | 86-95 Trucks & 4Runners | 6 | 04-16-2007 10:16 PM |
| need injector help 86 22re | rwhite | 86-95 Trucks & 4Runners | 4 | 08-08-2006 07:01 AM |
| 1988 4runner, v6 vs 22re | gilkey | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-04-2005 08:31 PM |
