IFS Sway Bar Link Bushings
Old 03-06-2008, 05:32 AM
JAV4-92's Avatar
I managed to tear up my passenger side sway bar link bushings on my '92. Aftermarket replacements appear to be hard to find and would rather avoid paying the $200.00 for the dealer part. I am curious about the following: Is there an aftermarket substitution? What other work should I perform while I have this done? What product/company should I look in to? (energy, OME, etc.) Tie rods and ball joints have all been replaced within the last year. The vehicle's rubber, however, is all original, all around.... Please advise. Thanks for the help.
Old 03-06-2008, 06:05 AM
90inworks's Avatar
Which rubber peice do you need? i bought a sway bar kit (the long bolts and all the rubber pieces) from napa for like 15 bucks i think.
Old 03-06-2008, 06:17 AM
JAV4-92's Avatar
Both metal plates, I believe, separated from the bolt. When under pressure, they make a clunking noise and can also be moved up and down along the bolt with your hand when inspecting them.
Old 03-06-2008, 06:47 AM
GSGALLANT's Avatar
The metal plates (or spacers, if we're talking about the same part) are not fixed to the endlink. If you're able to move the spacers up and down along the endlink, it sounds like your rubber bushings are just missing. Pictures would help, but if this is the case, just buy the 4 bushings from the dealership for $3 each and replace them (assuming you can take the nut off the endlink without breaking the endlink). I appologize if I'm not understanding your question completely. Post up some pics if you can.
Old 03-06-2008, 07:19 AM
Trail_Banger's Avatar
I got mine off EBay for like 24 bucks, including shipping. The part was fine and the bushings are holding up quite nicely. The stealership wants WAY too much money for them. Ever priced out a Toyota mudflap? That will make you laugh.
Old 03-06-2008, 07:28 AM
JAV4-92's Avatar
GSGALLANT: I see what you are saying. Let me snap some pics.
Trail Banger: I live in South Texas, the local Dealer wanted $208; need I say more.
I have contemplated getting rid of the truck in place for a newer model, but I can't get this one to fall apart. 245K (w/part time functioning Speedo). I'd like to just keep replacing the small stuff.
Old 03-06-2008, 07:43 AM
Aywilkerson's Avatar
I had to get mine done to, it was like 20 bucks at autozone
Old 03-06-2008, 07:48 AM
JAV4-92's Avatar
Aymilkerson: Was it the entire unit or just the bushings
Old 03-06-2008, 07:51 AM
Just the bushings all of them for the sway bar
Old 03-06-2008, 08:28 AM
Squiddy's Avatar
Energy Suspension makes the whole deal (as a kit) for fairly cheap -- bushings, plates, linker arms -- I got a set for about 25 -30 bucks (online). I put in a new sway bar, added these, handles much better on highway (I know, all the true crawlers shuddering in horror!)
Old 03-10-2008, 07:31 AM
JAV4-92's Avatar
Thanks for the help fellas. I will be placing an energy order this week.
Old 03-10-2008, 09:25 AM
Bear80's Avatar
What dealer did you work with?
Old 03-11-2008, 02:16 PM
JAV4-92's Avatar
Cardenas in Harlingen. Pricey. Service is terrible. I'm ordering the Energy brand bushings.
Old 03-11-2008, 02:23 PM
black diamond's Avatar
take the sway bar off and throw it away. problem solved. cost zero.
Old 03-11-2008, 02:45 PM
EWAYota's Avatar
x2. I haven't ran a sway bar on my truck in 3 years now.
Old 03-12-2008, 01:44 PM
JAV4-92's Avatar
So doing so will only make me dip a little more in the turns, correct?
Old 03-12-2008, 02:03 PM
jason191918's Avatar
It will allow each front tire to flex independently. Good for off trail. More flex. Bad for street. More body roll and increased rolling/skidding.
Old 03-12-2008, 03:00 PM
HelliphinoN8's Avatar
I took mine off 40,000 mi. ago and have had no problems. It's my daily driver too. It'll give you a little bit better flex off-road, but nothing crazy. The most noticeable thing is slightly more body roll.....no biggie.
Old 03-12-2008, 03:10 PM
waskillywabbit's Avatar
We offer replacement end links for your vehicle on the website.
nvdesertrunner
05-11-2020 08:18 PM
andrewtexas123
07-06-2016 01:49 AM
89fourrunner
02-17-2016 06:52 AM
bobjohnson2121
08-28-2015 04:02 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: IFS Sway Bar Link Bushings
