| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
IFS Diff Identification question
__________________
Rust-Free '88 Runner. Stay-at-home truck. |
#2 (permalink) |
I don't know if there is a ratio stamped on the ring gear but if you can count the teeth on the ring and pinion gears then divide you'll get the ratio.
This is how you can get the ratio if the diff is still sealed. Block one output shaft and turn the input flange until the other output shaft has turned 2 complete turns. The number of turns of the input flange is the ratio. If you want to be really accurate go for 20 turns on the output. |
#3 (permalink) |
Makes sense, thank you.
__________________
#4 (permalink) |
the ratio is suposed to be stamped on the ring, it will only be the first 2 numbers IE 4.1=4.10 4.8=4.88, but it isnt always stamped, i had got a 4.88 that was not stamped. the most reliable way is to count the teeth, a 4.10 will have 41 ring gear teeth a 4.88 would be 39 teeth . i use this example becuase this is what i know off the top of my head.
here is a calculator to help you out http://www.4lo.com/calc/gearring.htm |
#5 (permalink) |
You can also pull it off the vehicle information on the inside of the driver's door frame.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#6 (permalink) |
They wont always be stamped. Should have a make and model # or some kind of # somewhere on the ring and pinion that you could look up.
or just count the teeth =P
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#7 (permalink) |
you can i have done that before but that always isn't true, they make mistakes with stamping the plates all the time, I would have suggested that but he already had the diff out so to me it makes more sense to me to count the teeth just my opinion.
#8 (permalink) |
Okay, so the 4.1 stamped on this ring gear indicates to me that these third members are not worth very much money
__________________
#9 (permalink) |
Yep, just count then do da math. But, IF it's a factory gear set it will have the number of teeth stamped plainly on the side of the ring gear. Such as 39,41,43 etc. Oops this post was sposed to be #8, my bad, edit error.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 04-10-2007 at 11:58 AM. |
#10 (permalink) |
Possibly, but not necessarily. They could be custom cryo jobs.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! |
#11 (permalink) |
borrowing the thread real quick. what would the stock gearing be for a 94' 2wd pu? is it something that u can get options on from the dealer or will it always be the same stock? i tried to look on my diff, but couldnt find anything labeled on it. i'll probally look again. could it possibly be in the owners manual?
__________________
Dead '94 2.4L 22re 2wd pu, k&n air filter, thrush glasspack, 4in over stock rear shackles, 1.5in ball joint spacers, 4in infinity reference dash speakers, pioneer head unit, 10in p2 sub, alpine amp. bed cap topper thingy. great for campin. Current-2004 toyota tacoma, 2wd, 3.4L, prerunner, e-locker, tow package, trd package, ext cab, alpine head unit, polk speakers all around, punch p2 10" run off a alpine mono amp, silver paint. ohhhh its purty... |
#12 (permalink) |
The VIN # contains a gear/axle code, read this link to decipher. The VIN is located in the engine compartment on the firewall behind the engine, or the door jamb.
http://toyota.off-road.com/toyota/ar....jsp?id=274535 I'm gonna geuss, F072 (3:90)
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 04-10-2007 at 03:52 PM. |
#13 (permalink) |
i looked at my diff just now, and while i couldnt rly get a good look at it, cause its wet and i wasnt going to lay down and wiggle in and get all wet, but anyways, i saw the number 10 when looking from the front back. it was on the outer ring that bolts in. mean anything?
__________________
#14 (permalink) |
Isn't the pinion painted? Maybe that is just for the rear axle.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569 Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/ |
#15 (permalink) | |
Quote:
__________________
#16 (permalink) | |
Quote:
If you believe you've seen paint on a pinion it was most likely used as a marking agent when the gears were set up. I've seen it on every type of Toyota axle that I've opened. 2wd, 4wd, front axle, rear axle.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 04-10-2007 at 07:56 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IFS Diff Swap - Will 97 4runner V6 diff fit in 99 Tacoma 4cyl? | transalper | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-21-2007 06:26 AM |
| IFS is not weak, the 7.5 diff is.... | Toyofast | 86-95 Trucks & 4Runners | 29 | 04-18-2006 09:31 AM |
| HELP! 1G IFS Front Diff Question | kwando | Maintenance & Repair Archives | 14 | 06-27-2005 06:29 PM |
| IFS taco diff | RTdawgs | Offroad Tech | 17 | 02-10-2004 07:17 PM |
