Idling Stalling And Misfiring
Old Sep 6, 2008 | 06:33 AM
ALBERTA_TOYOTA's Avatar
1994 3 L pickup
i just put in a K&N cool air intake last night and when we started it up it was running fine. then after driving about 2 blocks it started to misfire and when you depress the clutch or let it idle at all it drops down to a point where it stalls slightly then shoots up to 1500 RPM then drops down to nothing then goes up to 1500 RPM and this goes on and on and either just does not stop or will actually stall.
any help would be great
__________________
Old Sep 6, 2008 | 07:11 AM
DeathCougar's Avatar
Did you make sure to plug the Airflow meter back in? And that your air ports are properly blocked or capped?
Old Sep 6, 2008 | 07:26 AM
abecedarian's Avatar
sounds like a pretty serious vacuum leak to me.
like DeathCougar asked- is the AFM reconnected properly and all tubes and ducts connected or plugged?
Charecter1
Nov 6, 2023 10:08 AM
Blamalam
Mar 12, 2022 07:34 AM
_Nicco_
Aug 28, 2015 07:26 PM
noosh
Aug 21, 2015 03:49 AM
Jnkml
Jul 6, 2015 01:20 PM
