Idling Rough?
Old 01-18-2010, 08:50 PM
allterraintoyota's Avatar
Idling Rough?
My 22re is idling at 1000 RPM when warm, is this too high? I know it is supposed to be around 750-800, but will it matter if its at 1000? I have tried to adjust the idling screw, but it is all the way down! What is the cause of this????
I will be cleaning my throttle body out on Wednesday, to see if that helps. If cleaning my throttle body doesnt help, I plan on doing the plugs, seafoam, and a possible valve adjustment. Any Ideas? I would really like to know why my idle adjustment screw is turned all the way down, and I am still idling at 1000RPM?? Could this be a timing issue? I had to replace my alternator a few months ago due to driving through a swamp, and I was wondering if not adjusting the timing on my belt could throw the idle off?
Any Ideas???
Old 01-18-2010, 09:40 PM
85yota4x4's Avatar
thats not too high, mine idles at about 1000 also
Old 01-18-2010, 10:23 PM
ibeamtaco's Avatar
vaccume leak can cause that high idel and yeah it schould be 800 850
Old 01-18-2010, 11:38 PM
peow130's Avatar
i need to raise my idle.
Darn thing idles at around 700, and it shakes the whole truck, lol.
Belts don't have timing, they're just belts.
The timing is all internal on the 22R/E, and the outer belts only spin the water pump, alternator, and PS/pump and AC compressor
Old 01-19-2010, 04:37 PM
4runnerx3's Avatar
If it shakes at 700, check the hose from the throttle body to the air regulator. They tend to get hard and crack and let extra air leak in. The hose is on the left side of the throttle body. If it's ok, check the injector seals. Spray some carb cleaner at the base of each injector and see if it revs up.
Old 01-19-2010, 07:53 PM
I am going to clean my throttle body tomorrow, I hope it will help, what is the best way to check for vacuum leaks? and where ?
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
markwink
08-18-2015 12:38 PM
Quick Reply: Idling Rough?
