idler arm bad or not?
Old 09-24-2008, 04:54 PM
ddwyer's Avatar
94 4x4 22RE 196k
I just got my truck inspected to find that I need an idler arm. Or so the mechanic tells me. How do I check the idler arm? If there is excessive play, do I need to replace the arm or is there a rebuild I can do?
Old 09-24-2008, 04:57 PM
fillsrunner4's Avatar
they are rebuildable
Do a search on it! I know there is alot of info here about the Idler arms and there woes and upgrades
Old 09-24-2008, 05:37 PM
HAVOC's Avatar
https://www.yotatech.com/forums/f128...ld-how-144151/
Old 09-24-2008, 05:38 PM
ahickman's Avatar
Just replaced the bushings in mine two weeks ago. Total cost = $15 from dealership and about 1 hour of time. Easy, easy, easy and cleaned up a lot of slop in the steering.
Read the following link:
http://www.4x4wire.com/toyota/maintenance/idler/
Aaron
Old 09-25-2008, 04:49 PM
leebee's Avatar
when you do rebuild it, drill and install a grease zerk.
lee
Old 09-25-2008, 06:15 PM
Beaniam's Avatar
between those 2 links there are 3 different part numbers listed for bushings ?
Old 09-25-2008, 06:17 PM
jason191918's Avatar
Enter your VIN here.
http://www.toyodiy.com/parts/q.html
Old 09-25-2008, 06:24 PM
Beaniam's Avatar
wow thanks
Old 09-25-2008, 06:25 PM
Originally Posted by Beaniam
wow thanks
Old 09-25-2008, 11:43 PM
Jay351's Avatar
The idler arm changed sizes in 92 or 93 I think. I got a junker 93 and the shaft has a larger diameter.
The part number I posted is for 91...
p.s who paid 15 bucks for these bushings at the stealer? They are like 7 dollars...
rusty904
03-27-2017 05:20 PM
andrewtexas123
07-06-2016 01:49 AM
kirkrunner
07-27-2015 07:59 PM
1994toyota
07-17-2015 03:03 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: idler arm bad or not?
