I like to dance, just not at idle
Old Nov 12, 2007 | 05:39 PM
lonestar's Avatar
I need ideas on where to chase the demon.........the low down->
87 runner 22re 168,000mi 3,000 on the total rebuild.. The only thing I didn't replace in or on the engine is the cam/rockers/valves/springs, but the head is rebuilt by someone I trust(as much as you can trust a machine shop)
Also, their are parts such as egr, cold start injector, start ignition time sensor, little things like that, that may be a part of the problem...
Question??
Why does the sweet little girl(with a heart of gold) bump at idle, like its missing???
PS:bored over 40, new plugs, wires, coil, cap, good looking vac. hoses, oxy. sensor, k/n open mouth, header, high flow a$$ end, new oe injectors, I think all grounds have been cleaned, aaaaaaaaaaannnnnnnnnnnnnnnnnnndddddddddddd!
I think thats it.
Mr. everchasingtherunningdemon,
LONESTAR
Old Nov 12, 2007 | 06:18 PM
WCorbett's Avatar
My 3.slow did that and i replaced the cap, rotor, and plugs and wires and it stopped.
Old Nov 13, 2007 | 06:54 PM
84sr5yoty's Avatar
What brand spark plugs and O2 sensor did you use? Anything but NGK and Denso and you have the strong possibility of the motor missing at idle.
An EGR stuck open will cause a choppy idle. You can temporally bypass it to see if it eradicates the problem.
Any codes stored in the computer?
Old Nov 13, 2007 | 07:09 PM
geTBeNt2NIghT's Avatar
try bosch iridium plugs, i had i 22r with similar mods on it carb cam 40 over ect. it ran like hell i had no idea why, heard about these plugs went and got them and the problem stopped. give it a shot, the plugs are alittle pricey though...
Old Nov 13, 2007 | 07:37 PM
WCorbett's Avatar
bosch
Old Nov 13, 2007 | 07:53 PM
gametom's Avatar
bosch on a toyota what! Go NGK or Denso
http://www.sparkplugs.com/results_ap...1&AAIA=1272350
Old Nov 13, 2007 | 08:14 PM
wow well anyway it worked
Old Nov 14, 2007 | 06:29 PM
lonestar's Avatar
First off, I've adjusted the valves from here to last tuesday and it never seems to make much of a difference(and yes with the engine hot). And I do have NGK plugs in it that are relatively new..... But I put bosch wires in it late one night after burning one on the header and Autosuck was the only parts store open. The EGR on the other hand has been in the front/back of my mind the whole time, and just never justifiable at $160 or $180 a pop... Any ideas where to get a good EGR that isn't quite so much?
What is a flat cam lobe, I mean, is it noticeable just by looking? When I had the motor out, I looked real hard at the cam to see if it had to go but $$$ was really tight. Oh yeah, how should I bypass the EGR?
thanks guys
lonestar
Old Nov 14, 2007 | 06:51 PM
James Dean's Avatar
I agree. If I run anything else in my 3.0 it runs like crap. I've tried Bosch and a couple others, never ran them more than a month before I threw them away.
Old Nov 14, 2007 | 06:58 PM
lonestar's Avatar
Amen Brother
Amen
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
