how much coolant to use on a 3vze
Old 04-14-2006, 06:58 PM
pruney81's Avatar
I'm going to drain my cooling system tomorrow, how much coolant should I put back in and does anyone recomend toyota over prestone?
Old 04-14-2006, 07:11 PM
ChickenLover's Avatar
My fsm lists the capacity at 10.5 quarts for the 3vze.
Old 04-14-2006, 07:21 PM
pruney81's Avatar
Yea mine does too, but I'm only going to be draining my radiator, 10.5 is 2.5 jugs...I thought when you drained and refilled it you only use 1 jug and distilled water for the rest
Old 04-15-2006, 08:41 AM
eric-the-red's Avatar
10.5 is the total capacity, so that would be 5.25 of coolant and 5.25 of water. You could probably get away with one jug of coolant, but for maximum protection you should use a 50/50 mix.
As for Toyota or Prestone they'll both work just as well.
FilthyRich's Avatar
spring for toyota red coolant
moparbay
03-10-2023 03:50 PM
MadMax48
03-03-2020 10:33 AM
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: how much coolant to use on a 3vze
