How To Judge Pitman Arm Condition????
Old 06-11-2008, 08:15 AM
qdude79's Avatar
Question How To Judge Pitman Arm Condition????
Working on freshening my steering before having relay rod recall work.
Replaced: inner/outer tie rods, upper/lower ball joints. Wheel bearings inspected/repacked/etc. After getting them all buttoned up, started yankin' on the whole setup by hand, noticed play where the idler arm attaches. Going to replace that when the new one comes in.
Question: I see no play whatsoever in the Pitman arm. Is there a specific "something" I should be looking for? To my knowledge, this is the last part of my steering to look at, and don't want to replace it if it ain't broke, as they're a real "female dog" to do, but I will if it needs replacing. Just don't know what to look for to judge the condition of it.
Advice? Experience?
Qdude
Old 06-11-2008, 04:41 PM
qdude79's Avatar
It's that arm that comes off the bottom of the steering box??????????????
Old 06-12-2008, 09:27 AM
dirtoyboy's Avatar
As long as you havent tried to heat treat it yourself or gotten in an accident or something it should be fine...just make sure the nut is torqued to FSM specs
Old 06-12-2008, 09:29 AM
qdude79's Avatar
Thanks! It looks untouched from the factory... Guess I'll just keep an eye on it for a few thousand miles.
Old 06-12-2008, 07:03 PM
ewong's Avatar
cant the ball joint thingie on the end of the pitman get sloppy?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
aowRS
09-13-2017 08:22 AM
altydog
09-20-2015 07:37 PM
JRB4Runner2015
09-20-2015 12:29 AM
BimmerSage
09-17-2015 11:48 PM
Quick Reply: How To Judge Pitman Arm Condition????
