How to deal with a rounded tranny fill bolt...
Old 02-11-2010, 06:03 PM
Toyomo's Avatar
SHould've expected it. I was about to change the oil for the tranny today, but I can't undo the fill bolt at all. I PB blasted the hell out of it, used a hammer to tap it slightly and it ain't budging at all.
Anyone have any suggestions/ideas for this? Luckily I didn't undo the drain plug first, but do they sell replacement fill/drain plugs at the auto parts stores or is it a dealer only item?
Old 02-11-2010, 06:07 PM
mightymouse's Avatar
junkyard! Probably get it for free if you throw it in your pocket. Not saying i condone that kind of behavior but to each his own. plus while your there you can find other crap you need. If you like me a trip to the local yard has yielded many good finds even when i'm not looking for anything. Otherwise yeah probably the dealer.
jason191918's Avatar
#1 Try a pipe wrench.
#2 Weld a nut to it.
#1 failed for my rear diff, but #2 worked like a charm. From the heat of the weld, it was finger tight afterward.
I bought mine at a local parts store.
Old 02-11-2010, 06:15 PM
1989toy4wd's Avatar
vice grips + Hammer???
If its already rounded off then you dont really have to worry about making it worse!
Old 02-11-2010, 06:17 PM
67ghiaTIV's Avatar
I have had succuess using a punch or chisel on the edge and tapping it with a hammer if you are having trouble looseing it.
Jamie
Old 02-11-2010, 06:23 PM
874runnersr5's Avatar
Extractor sockets?
Old 02-11-2010, 06:31 PM
89silverpu's Avatar
You can always take the shifter out and fill it through the shifter hole as well with a funnel. That's what I did when I found out my fill plug was stripped.
Old 02-11-2010, 06:36 PM
Toyomo's Avatar
Oh. I just might end up doing that. I gave up for the night, has anyone had any success with the extractor bolts? I can pick up a set at sears for 20 bucks.
allnmstkn313's Avatar
Heat+Vicegrips.
Failing that weld on a nut and be done with it.
Old 02-11-2010, 06:38 PM
a nut is a couple of bucks and a 6 pack is cheap. have a buddy weld a nut on
Old 02-11-2010, 06:44 PM
camo31_10.50's Avatar
i always grab atleast a couple drain plugs if there is nobody lookin lol
and the thought (i'm NOT going to do this...it's just a straight up bad idea..LOL) has crossed my mind before on going into the yard after dark and getting a grille for my '86 that they want $75 for!!!!...like i said though..i don't steal...lol and i have asked the owner of the yard before if he minds me grabbin bolts and such and he don't care, but his employees flip over it lol
Old 02-11-2010, 06:52 PM
Slowrunnin's Avatar
I just changed my tranny and transfer case fluid a couple weeks ago. I used a Impact gun to remove the fill and drain plugs. Just make sure you hold the gun on there firmly.
Old 02-11-2010, 07:01 PM
He already rounded it off.
Old 02-11-2010, 07:30 PM
yep.. its what i use at the shop.
Old 02-11-2010, 08:46 PM
Fossilized
Staff
dropzone's Avatar
that is why the allen head insert fill/drain plugs are the choice for replacement...
Old 02-11-2010, 09:00 PM
The aftermarket hex head one's are about 3 times as thick as the stockers, making them a lil bit harder to strip.
Old 02-11-2010, 09:18 PM
tc
tc's Avatar
Anti-seize and aluminum washer when you put it back in.
Steel bolt in aluminum casting = no bueno
Old 02-11-2010, 10:16 PM
mick cassidy's Avatar
been there done that first off get a PROPER SOCKET i think its a 22 mm DONT FORK around with trying to find a standard thats close thats why this happened !!!
hammer and chisel it out tapping it out one tap at a time its soft alum now get a replacement from the boneyard or da dealer and lesson learned metric on metric
Old 02-11-2010, 10:44 PM
nj110167's Avatar
Vise Grips and a hammer
Old 02-12-2010, 05:14 AM
RustBucket's Avatar
24mm
Apply heat with a torch for a few seconds and tap the bolt head tangent to the center with a chisel and hammer.
Quick Reply: How to deal with a rounded tranny fill bolt...
