Hole in Axle Housing After Removing U Bolt- repair or replace?
Old 10-24-2015, 06:43 AM
Joe Zanone's Avatar
I'm talking my first project and it looks like you all may be able to help me with a problem I came across. I'm trying to install the Rancho Add A Leaf kit. I've got the wheels off and just got the u bolts off and the bottom plate. Once I did that, it looks like a small chunk of the axle came off right where the middle of the bottom plate was and there is differential fluid coming out. Can I fix this somehow (and how would I do it) or do I really need to replace the entire axle as a friend told me?
Old 10-24-2015, 06:50 AM
wyoming9's Avatar
Red face
A picture would be of great help
Since your asking this question instead of telling us how you fixed this issue
My bet would be you would need to pay to have this repaired??
At which point swapping out another housing might be much cheaper.
This is just a guess without pictures
I would love to see just what your talking about.
Old 10-24-2015, 01:09 PM
Staff
Terrys87's Avatar
I would probably replace the axle if it was me. Here is the codes to determine which gears you have.
Old 10-24-2015, 07:07 PM
muddpigg's Avatar
Definately post pics, interesting. I'd replace it. A housing should be that expensive. Check shaft bearings for good measure. Don't want one failing on a semi-floater.
Old 10-25-2015, 12:51 AM
wyoming9's Avatar
Red face
I gotta wonder did the spring perch break off and the only thing holding it in place was the u bolts??
I would think any cracks at all would push gear oil out unless it was not driven long enough to get the gear oil hot.
Is this a new to you vehicle that was sitting behind the shed for sometime before you bought it???
Blamalam
03-12-2022 07:34 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
TJWilly
07-31-2015 02:05 PM
Dakotaneu
07-27-2015 12:03 AM
Quick Reply: Hole in Axle Housing After Removing U Bolt- repair or replace?
