high pinion flange bolt pattern v v6 driveshaft
Old 07-30-2011, 09:05 PM
Sombrero's Avatar
so i will be doing a sas soon and am wondering if my v6 drive shaft bolt pattern will fit on the high pinion differential, so i can just mod that, or if i'm going to need to get a new flange like a 5 bolt pattern one from marlin.
Old 07-31-2011, 06:06 AM
waskillywabbit's Avatar
Front IFS dshaft CV won't work as it doesn't have enough degrees of freedom.
:wabbit2:
Old 07-31-2011, 06:26 AM
blake.nemitz's Avatar
i just turned mine 45* and drilled new holes. also like wabbit said your stock cv wont angle enough without modding. even with modding it may not. i overcame this issue by runing a single joint at each end and made my own shaft with a trail gear spline
Old 08-01-2011, 03:40 PM
Sombrero's Avatar
thanks what whould you suggest just getting a drive shaft made?
Old 08-02-2011, 03:22 PM
anthony1's Avatar
You need one of these...
http://www.marlincrawler.com/axle/dr...ront-driveline
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
Braparus
42
06-30-2016 12:17 PM
trailgoat
08-13-2015 05:54 PM
kirkrunner
07-27-2015 07:59 PM
Quick Reply: high pinion flange bolt pattern v v6 driveshaft
